353 props and speed?
Just curious what speeds and props you are running with your 353?
I've got 500 efi's and 30p bravo 1's. Best I've seen was 77.9 with just ove 1/2 tank of fuel. Approx 5100 rpm. I guess I expected just a little more out of her. |
Originally Posted by soonenough
(Post 3391704)
I've got 500 efi's and 30p bravo 1's. Best I've seen was 77.9 with just ove 1/2 tank of fuel. Approx 5100 rpm. I guess I expected just a little more out of her. That's right within a couple of mph. You can tweak the props for another 1 or 2 maybe, but you are real close. I personally wouldn't spent the $400- $800 to pick up the last couple of rpm's/ mph. Dave |
(Post 3391704)
Originally Posted by Bad Bird
(Post 3392744)
I have a pair of 525's and I'm running 5 blade 28's Mercury Maximus. Top speed so far is about 76-77 on GPS
You should be able to run 79-81. Need to loose the difuser rings, will give you a couple. Do you have ITS? Dave |
4 Attachment(s)
The 353 hull really gains BIG MPH from more power
Easy over 90 with twin 600 - almost 100 with twin 700 Props 32 Maximus lab finished 600 - 1,50 gears 700 - 1,35 gears compared to 496 HO `s 73-75 MPH and 525`s 76 - 80 MPH The 600`s are the very best package You only gain about 5 MPH from 425-525 13 MPH from 525 - 600 another 6 MPH from 600- 700 (not available from factory) Would be interesting to see speed numbers of the new 8.2 HO `S |
(Post 3392744)
Originally Posted by pokerrunboats
(Post 3392926)
I'm just poking around low 70s with my stock 502s and 28p 4 bravo 1s, might do a little work on her for some more speed when I get down South.
Originally Posted by axapowell
(Post 3392763)
At what rpm?
You should be able to run 79-81. Need to loose the difuser rings, will give you a couple. Do you have ITS? Dave No ITS.....B Blades did the props, thanks for your suggestion last summer, they did a nice job...no diffuser rings. Still struggling to get her dialed in any faster. |
(Post 3393054)
Something doesnt seem quite right. The guy I just bought my trailer from has an 05 with 525's, boxes with ITS and was running 82-83.
Interesting #'s there. So the 500 efi is running close to the same speed as the 525. |
(Post 3393781)
I'm struggling to believe the 496 HO's will push a 353 to 73-75 MPH. The 525's are a total 200 more horses and only producing a few more MPH for most 353 owners.
