292 SR1 Project
1 Attachment(s)
Well the fun began today on the 292 SR1. For the most part everything on this checks out solid and intact. I fired up the engines today, which both ran good other than I couldn't get water to come out the exhaust. I thought there was a drain open somewhere but I couldn't find it. Then I found it. When the engines were winterized the oil coolers were not drained. Both of them popped the end off. So I think friday I'll be pulling one of the engines so I can replace the coolers. Not a big deal, I have one laying around from my 242 and I can get a replacement for the other easy enough. Either way here are a few pictures, first one is as I got it, being towed home to Michigan here! I'll add more as I go but the project is pretty much going to be on hold until May 24th.
awesome, I think the rubrail is missing, when you get a new one make sure you put a white one on really nice update
3 Attachment(s)
Here are a few more after a good bath. I took 3M Finese It to the Imron and it buffed out to like new. Then some 3M super duty to a small area of gelcoat and it polished up great as well... A couple days of buffing and the exterior should be looking near new.
Originally Posted by 88242LS
(Post 3394720)
Go Black with a stainless insert, white doesn't match the gel color on the older boats very well, and shows scars...
Stainless adds like $300 and lasts forever |
Congratulations on the boat. That will be a great project, I missed it by a couple of hours... (I was on a buisness trip)
I'm in Holland, how far north are you? or what lakes should I look for you on? |
I'm in Onekama and will keep the boat on Portage Lake. I may bring it down to your area this summer, I've got some buddies in the Grand Haven area.
Originally Posted by endeavour32
(Post 3395040)
White worked out great on our 242, so much easier to clean and doesn't fade. So well in fact that the 311 is getting it this week.
Originally Posted by 32 vette
(Post 3395048)
Looking good
Nice lookin boat. I can't believe that the former owner wanted to part it out. Good luck with it.
2 Attachment(s)
A few more updates. Here is a picture of the hull before and after. For those of you that didn't see the boat, it was dull, streaked, and chalky.
3 Attachment(s)
Interior also is cleaning up very nice... Everything is done in there except the v birth. Carpet, seats, ect all look very good now! Again before/ after!
1 Attachment(s)
Most of the vinyl cleaned up very well except for the rear seat bottom and the sunpad. Thats the next project.
Originally Posted by formula242-502
(Post 3395061)
(Post 3397500)
Originally Posted by srdrago
(Post 3398017)
What did you use again???? I have the same problem and want to make it look new!!!! (I really dont want to wet sand)
I'll get some pics this week and send them to ya.
(Post 3398017)
Well I just thought I would make some updates to the progress of the 292. I had some bugs to work out of the ignition and fuel system but I think I have everything licked now. I bought a set of Hydromotive Quad IV props that seem to be working great, I got a top speed so far of 62 mph which is ok I guess for stock 330's. I did pick up a set of 454 mags that I've going to bump up to 420's which I'll install over the winter. I just recieved the new rub rail which I decided to stick with the black instead of white. I'll get some updated pictures once I get the rub rail on. All in all it seem like a great boat but I haven't had much time actually running the boat, 95% of the time so far as been tracking down issues and fixing them.
(Post 3426425)
Well I just thought I would make some updates to the progress of the 292. I had some bugs to work out of the ignition and fuel system but I think I have everything licked now. I bought a set of Hydromotive Quad IV props what seem to be working great, I got a top speed so far of 62 mph which is ok I guess for stock 330's. I did pick up a set of 454 mags that I've going to bump up to 420's which I'll install over the winter. I just recieved the new rub rail which I decided to stick with the black instead of white. I'll get some updated pictures once I get the rub rail on. All in all it seem like a great boat but I haven't had much time actually running the boat, 95% of the time so far as been tracking down issues and fixing them.
What about the 242 LS, stil got it? |
Nice project, looking good. I think the SR1's are the some of the best looking boats made. Sticking with the black rub rail is a good call IMO, keeps that old school classic look. Some guys have been on me to change mine to white but I like the black better.
I too replaced the white rail on my 272 with a black/ stainless...
Looks sweet. bling! pm me a ph# and I can send a pic from my phone if you'd like... |
Originally Posted by Monaco20
(Post 3426937)
Nice project, big boat almost 31 fot with the silentthunder platform??
1 Attachment(s)
Well its time to revive this tread! The only real issue I had with this boat this summer was getting all the sediment out of the fuel tank, after a lot of frustration, fuel filters and time the boat runs great. I put a set of Hydromotive 24 pitch Q IV's on it and got a top speed of 63 MPH on the GPS. Not bad for stock 330's. I'm in the process of pulling the 330's and building a pair of 550 hp 454's. Hoping to see upper 70's with that power. I'll post pictures as I re-start this project. Here is a picture of it in the water this summer!
(Post 3543926)
| All times are GMT -5. The time now is 03:56 PM. |
