-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   88 223LS prop for a 502 EFI (https://www.offshoreonly.com/forums/formula/253427-88-223ls-prop-502-efi.html)
Rob Lee 05-12-2011 12:04 PM
Any suggestions? I'd like a 4 blade Bravo.
chewymalone 05-12-2011 12:09 PM
24P would be my guess.
Rob Lee 05-12-2011 12:49 PM
Thats what I'm thinking too. 22P will not be enough.
sprink58 05-12-2011 02:28 PM
Take a look at these folks...they have some impressive equipment.
http://www.hydromotive.com/main.html
02603sec 06-06-2011 09:05 AM
I was out on June 4th. Old Gas 5000 rpm, 52 mph (gps) 55 on the speedo. with a 22p 4 blade bravo 1 (not labbed). I have the black 502 mpi bravo 1 in a 271 sr-1 1993, so I believe it's a 1.65, now that I understand most formulas with the black 502's had 1.65's I've seen recommendations all over the place for 271 props. Wurl seems to have tried them all. makes me wonder if mine would turn a 28.
Monaco20 06-06-2011 09:50 AM
Cant be correct prop.
I have a 242SS 454 330 HP Bravo1 1,50
mirage 21 plus. Seen 50 on the gps (with bottom paint)
Your boat should go closer to -60 mph
god luck chaesing correct propeller :-)
moparjet 06-06-2011 01:35 PM
i just ran 60.0 on gps with a 23 three blade with carb. 502.. 242 ls.. spins right at 5100 rpms
bacon1 06-06-2011 05:41 PM
My 89 223ss with the stock 454 ran 58 on gps with a 23 older style mirage 3 blade if that helps.
Screamin Chicken 06-08-2011 03:19 PM
My 88 223LS - 502 mag 1991, milled and pocket ported rectangle port heads, 24 degree ign box, no1 rapidfire spark plugs, premium fuel, 24 pitch bravo one reworked, spins to 5000 on gps 68 mph
