-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Formula 206 needs new engine...? on compatibilty (https://www.offshoreonly.com/forums/formula/253865-formula-206-needs-new-engine-compatibilty.html)
formula18 05-18-2011 04:07 PM
I currently have a 1989 206ls with an older motor retrofitted with vortec heads and intake...I need a new motor as the one in the boat is knocking...im currently tearing it down...my question is...obviously id like to stay as cheap and reliable as possible...will a vortec long block fit or will it not match up with the alphaone thats back there...i know there are limitations to that as well but i would like more than just the 270 horsepower long block rebuilts i keep seeing..any ideas?
motor is a 1989 5.7 already rebuilt once
thanks , Harry haven't posted in quite some time as i just recently bought a house and ive been preoccupied with fixing that up lol
edit: i could just get a rebuilt non vortec but obviously id have to have the vortec heads i have rebuilt so that will cost extra money too....hmm what to do...im on long island as well if you know anyone local...willing to drive
Baja226sport 05-18-2011 05:45 PM
Any small block 350 will bolt in place. I wouldn't put a ton of power through an alpha but as lonng as you don't go to far over 300hp I think you will be ok.
Check out 1800runsnew.com
They have a bunch of options and they are priced reasonably as well. I think they ar ein connecticut or something.
I got a 502 from them about 6 yrs ago, it went in a 27 warlock, then a scarab, then a sunsation with a whipple on it and it is still running 85 mph!!!!
86242ls 05-18-2011 05:55 PM
If you up grade to a vortec block you will need to change the flywheel the back of the crank is different. I upgraded my original 260 a couple years ago with a vortec motor, came with roller valve train, I put a nice comp cam in it and roller rockers. All original parts other than flywheel crossed over. Ran great until I upgraded to a bbc.
Baja226sport 05-18-2011 06:43 PM
Sorry.....I was speaking of a bobtail swap. I wasn't thinking........86242 is right about the flywheel....
sprink58 05-18-2011 10:09 PM
One option that makes sense for you would be to get a rebuilt short block "non Vortec". Have your Vortec heads freshned with a valve job and re-use them with your existing Vortec intake,etc.
To warm it up a bit and take advantage of those Vortec heads add some 1.6:1 ratio rocker arms...adds a bit of lift to the valve train without getting stupid.
Check this site out http://www.rlcperformance.com/images...pledigits.html.
There are some good tips on ways to get 100 mph out of a 22 ft boat with a single small block and an Alpha drive. I was suprised that with a few relatively minor "bolt ons" these guys were able to get a 22 foot Stingray Maxxim to 70 MPH.
Have fun!!:evilb:
Perlmudder 05-18-2011 10:44 PM
and insert triple digits comment here _____________
formula18 05-19-2011 05:16 AM
thanks guys
