-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Gorgeous old 23' on...... (https://www.offshoreonly.com/forums/formula/260429-gorgeous-old-23-a.html)
Twin O/B Sonic 08-17-2011 06:24 AM
e-bay. I'm a big fan of the older boats and as soon as I get sick of my O/B's I'll probably go shopping for a mid/late '80's 24.
Love this one too. Looks very well done. Course pix's is pix's ;)
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
sprink58 08-17-2011 06:58 AM
Wow...that is nice...hmmmmm. That boat looks like it could use a change in latitude...:evilb:
bigmike253 08-17-2011 11:35 AM
That boats been for sale for about two years. Not sure the graphics match the boat though. Looks to be well kept up.
srdrago 08-17-2011 05:19 PM
Whats your price rang. I have a 85 242 with single 350 380 hours all freshwater (Freshwater coolant system in it right now). Thru hull exhaust mint condition.
machloosy 08-18-2011 10:01 AM
Wow... I like that 233!!! I want mine back with twin small blocks! Sprink, whats that 233 turn with twin 300hp ish small blocks?
bigmike253 08-18-2011 01:28 PM
mach, I'm guessing 65, or at least thats what I'm hoping for when mine splashes in a few weeks
sprink58 08-18-2011 02:00 PM
About 65 without anything special...solid 50~55 mph cruise....and that's with a pair of stock 260's. With these old hulls with the hook at the chine/transom 70 mph and beyond becomes silly because you can't control the boat. The sweet thing about more power in these hulls is that you don't necessarily go any faster on the top but you get there very quickly.:evilb:
machloosy 08-19-2011 09:58 AM
I knew I was on borrowed time with the OMC 233 but I want a merc version!!! I remember getting air over a 55ft cruiser wake, another boater said "you could haven driven a car under your boat it was up so high". A friend and I got wet, but not drenched like I expected and she landed like a cadillac :eek:
JP-8 08-24-2011 11:44 PM
That is a very nice 233. I wouldn't turn my nose up to one with twins, figuring I could easily convert from an alpha to a bravo setup with shorties to maintain relative prop height. Some lightweight 427 small blocks would wake things up.
Several weeks ago, I picked up an Interceptor that has a 502 HO with Gil dry exhaust, and a nose-coned TRS drive. I found it odd that there were no trim tabs installed from the factory, as every brochure picture I've ever seen shows them as standard equipment.
Plans are to install a pair of Bennet dual ram tabs and re-do the cockpit and cabin. A set of period-correct bolsters will replace the swivel bucket seats. Also may consider relocating the throttle to a more ergonomic location like in later SR-1's. In the end, I'll have a 233 with SR-1 appointments. Something Formula really should have done in the first place.
The boat will do around 66 MPH with a 23p Mirage (I haven't had it out yet, so I'm just going by the previous owner's experience).
I also have a 22p Bravo 1 prop that should yield close to 70 MPH. I believe that it may be viable with the addition of a hydrofoil to the drive. This would not only enhance stability, but would help direct the prop wash (lots of wasted motive force) into usable rearward thrust.
I had hoped the hook would not be too limiting a factor, but a little experimentation is in order.
78CIG24 08-26-2011 09:27 PM
Twin O/B Sonic,
When you are ready to take the plunge let me know. I have a "Virgin" F-233 Hull/Deck that is just begging to be turned into a #16 replica or something similar.
Hull has never been rigged, and been in dry storage most of it's life. Cabin interior was finished years ago (needs re-glued in places), and a few other details were done, the rest is untouched.
http://lh5.googleusercontent.com/-gF...-32-12_339.jpg
http://lh3.googleusercontent.com/-47...-13-31_551.jpg
http://lh4.googleusercontent.com/-jl...-30-38_442.jpg
http://lh5.googleusercontent.com/-1k...-32-32_946.jpg
With just a little bit of work (and undo a few things already done), especially with your skills.....it could look like this in no time at all... :-)
http://api.ning.com/files/0CxGDb8l0I...=no&type=pjpeg
