I run the 23 Mirage and they work great.
Originally Posted by Car Biz
(Post 3516480)
You might want to try a pair of 23 standard mirages not the pluses. My old 272 (87) i did a prop test back to back to back
Cleavers 21 Mirage 23 Mirage The 23's gave the best performance all the way around cruise top end and out of the hole. I had stock 260's. Funny i ran that thing up and down the river four times and never could get it to break 60. 59.9 was all it had BUT it cruised @ 38-40 @ 3300 that was GREAT for me.:drink: |
Originally Posted by Formula 04071
(Post 3516806)
Just wondering because there are deals to be had on standard Mirage props that are pre-Mirage+. |
Originally Posted by sprink58
(Post 3516837)
Help me understand what I don't know....having not run a Mirage vs Mirage+. I have been told that a Mirage+ will equal the performance of the standard Mirage plus the equivalent of 1" of pitch...(i.e. 21" Mirage+ is equal to a 22"...a 23" Mirage+ would equal 24") is this about right?
Just wondering because there are deals to be had on standard Mirage props that are pre-Mirage+. Thats why a standard 23 was alitte better for me as i had alittle more pitch to move the boat and could still turn it 5000 |
Originally Posted by Brad Murphy
(Post 3512141)
Hey all, I just purchased a new to me 1986 272 SR1 with twin SBC's. Im sure I will have some questions and need some advice on this in the near future. There are already changes and upgrades going through my head :drink:........Brad
Brian |
Ok, I will start looking for a couple stadard Mirage 23s then.
befu, yes that is the one. Its in pretty good shape just needed a little TLC. This past weekend I buff and waxed it and it really came back to life. Its really got a mirror finish now so I was pretty pleased that my hard work paid off. I did discover an issue with shifting the port engine in reverse. It isnt dropping the RPMs like its supposed to and dies out everytime you shift in reverse, foreward is fine. Isnt this an ignition switch or something to momentarily stall the engine?? And how do I fix???.......thanks Brad |
(Post 3518284)
befu, yes that is the one. Its in pretty good shape just needed a little TLC. This past weekend I buff and waxed it and it really came back to life. Its really got a mirror finish now so I was pretty pleased that my hard work paid off. I did discover an issue with shifting the port engine in reverse. It isnt dropping the RPMs like its supposed to and dies out everytime you shift in reverse, foreward is fine. Isnt this an ignition switch or something to momentarily stall the engine?? And how do I fix???.......thanks Brad Both of these are relatively minor issues. You can disconnect the switch temporarily on the port engine until you get it sorted out...simply by disconnecting the wire from the switch to the coil. All it does is momentarily kill the spark when the shift cable is in a certain position. Since it's working going into forward...I suspect your issue is cable adjustment. Check a Mercruiser service manual for the adjustment procedure. |
Ok I will check that out. Your probably right on the adjustment because it does go in forward just fine....thanks for your help sprink. I have another question. This is my first twin engine boat, should I put a tie bar on it? Does it help alot or is that more for a higher HP set?........Brad
(Post 3518284)
Brad Figures! Let me know if you need to sell it! :drink: Gotta look at a 311 and there is a nice looking 272 on here in the classifieds down in TN also. Need to decide if the 27 or 31 would be the best fit for our "NEEDS"! Brian |
(Post 3519137)
Originally Posted by befu
(Post 3519639)
Figures, I so wanted to go grab that one, just timing was off on my life. Watched it sit on Ebay without a hit and damn near hit the buy it now button. Was hoping it would still be there in a month or so. Oh well, something will be out there when I am ready in the next 1 to 6 months.
| All times are GMT -5. The time now is 04:07 AM. |
