Repo formula on ebay with blackhawks
Needs motor work is an understatement if the blocks are cracked!!
too bad someone butchered the interior
Wonder what the speed would be with two good running 502 mags. think it was a factory blackhawk boat? cant you usually tell by the x dimension? you can bolt a blackhawk on a bravo transom assy right?
Originally Posted by Fixxxer22
(Post 3560901)
So, they only made 5 and this one had to go down like this... Nice.
lol
lol.. I have one running 502.
Too much considering the seller's terms. Looks like a title shell game after they have the money. I bought off lease once from GE capital, and they lost all the documentation on the equipment. It was aggravating.
lot higher then i was thinking already
I sold one of these back in the day...........To a very nice older gentlemen. The boat had stock a 70 mph speedo and we had to replace it 3 times with the needle wrapped around the starting peg.
I believe it would run in the upper 70`s when it was new a the drop of a hat. The Blackhawks worked ONLY on this boat..........They tried it on several other sized Formula but lacked the performance upgrade they saw on the 303. Tuck the drive in and hammer down you could hit the trim when you started moving the throttles............Took off like it was shot outta of a gun!!!! Resold it a couple of years ago and it looked as good as the day it was purchased new.........Still he at LOTO I believe.............. Capt. Steve :cool-smiley-011::cool-smiley-011: |
doing alot better then I thought
| All times are GMT -5. The time now is 05:29 AM. |
