(Post 3596963)
I have never seen a boat trailer with weight distributing equipment on it. The max weight on the truck towing is 8,500 (same for the dually too)......see page 29 on that PDF.
http://www.drawtite-hitches.com/prod...er_Hitch,45297 |
(Post 3596972)
What truck?
Thanks to all for your input. As for the pics. I'll do that when I get her wet.
Originally Posted by t500hps
(Post 3597027)
Brian has a 99/01 (?) Ford 7.3L 4dr 8ft bed dually.
Originally Posted by whistler
(Post 3597029)
(Post 3596963)
(Post 3597032)
So the it's not rated for towing more than 8500 without the load distribution hitch right?
I scraped the stock (junk) Class-III hitch. (called the V5) It is the HITCH RECEIVER's requirement in for the case on my truck that required the WD setup, that is--with that stock hitch. I upgraded to a Putnam (out of business) true Class-V hitch rated to pull 15K lbs., weight carrying. (no WD required) I did the same on my previous truck, Avalanche 2500, also rated for 12K lbs. I dumped the stock hitch, (affectionally known as the Flexi-Flyer); and put a true Class-V Putnam hitch on that as well. Also, most hitches ship with Grade 5 bolts. Dump the Grade 5 and go with Grade 8 bolts, and I like having them long enough to double nut. (Double nut is always better than single nut. :D ) |
WD Hitch......not the same as upgrading the hitch to Class V. Just upgrading the hitch doesn't upgrade the truck GCVFR.
The stock ford hitch is supposed to be a class 5 on a F-350 dually. It is a 2.5" style. The aftermarket class V hitches are more solid for sure, I just weld two gussetts on a angle to triangulate the rectangle box so you can still get the spare tire in....does the trick
What is GCVFR?
I spoke with one of the guy who runs Ford Service for Texas, and got clarifications on the hitch and that stuff. In MY case, my truck came with the "V5" hitch which is a 2" piece of garbage. (The NAME of the hitch is he V5. Its really a Class-III hitch. Confusing and bullchit, i know; blame Ford, not me.) SOME Ford trucks came/come with the 2.5" hitch which is solid piece and a true Class-V hitch. |
| All times are GMT -5. The time now is 10:49 AM. |
