-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Early 90's formuls (https://www.offshoreonly.com/forums/formula/270612-early-90s-formuls.html)
FIXX 02-13-2012 04:14 PM
Early 90's formuls
was just wondering if its just mine or are they all built like this and this was over looked..
I have a 1992 336,i was in the engine bay pressure washing..i aimed the wand at the foreward bulkhead and low and behold i took the paint off it,upon further inspection i noticed that the bulkhead was soft,formula just tabed in this forward bulkhead and just tabed around the center stringer..THEY DID NOT GLASS THE WHOLE BULKHEAD IN..then they painted over it..the rest of the stringers and transom are solid as a rock and you would think thet would have done the same to the bulkhead that holds the center stringer which holds two engines..
thanx in advance for the replys on how your formula if built..
Car Biz 02-13-2012 05:43 PM
Yup my 311 was the same way. When i did the motors i had a glass guy fix mine.
Secret Formula 02-14-2012 12:31 PM
They are not all built the same as mine does not have a forward bulkhead.
befu 02-14-2012 03:41 PM
my 86 272 is the same way. Getting ready to repair the bulkheads and other wood. the forward stringers but up against that bulk head so wood to wood contact with the one piece exposed.
Nice work......... :angry-smiley-038:
Brian
aquaforce 02-14-2012 05:53 PM
My 89 242LS is built that way but seems to be ok. My SS has a little softness at the top but seems ok otherwise. I'm not thinking to do anything about it until there is a more pronounced need.
befu 02-15-2012 09:53 AM
My 86 was only noticably soft where the mid bulk head was exposed at the top. But once you start digging into it, watch out! My center stringer is now being replaced, the bulk head is over 70% out where it got wet and the stringers going forward are wet. They are strong as hell and the boat feels very solid, no flex in the cockpit at all. But there is water in there and will have to be dealt with.
Everything had felt solid to me also except for that one bulk head to either side of the main stringer, not all of it. Checked the transom and it is dry thank God! A lot of the wood came out hard from the bulk head and stringers, it was wet not rotted. I do not see how the center motor stringer on all of these is not wet with how they built them and then left them open on the bottom! As long as I am into it, I am doing it once and then the motors are going back in.
Brian
FIXX 02-15-2012 07:50 PM
fixx
Thanx for the reply's..one would think with the reputation that formula has they wuld at leaste spend the extra money on what vary little it would cost them to at leaste glass the that section of the boat in so we the people that cant afford a newer boat would not have to go through this...this will be the last formuls i will buy after seeing the way they cut corners to save on a little weight and dollars..:angry-smiley-038:
theadamv1 02-16-2012 07:19 AM
cant say that I would never buy another Formula for that reason, I am sure that their quality has increased over the years from the eairly 90's... Nothing last's forever... And one thing I can assure you that any older or even newer boat you inspect with a fine tooth comd you will find some kinda quality issues..
[email protected] 02-16-2012 05:22 PM
I have see alot newer boats with more rot than that. IMHO "whole transoms" Believe it or not Formula Knows how to seal a boat up.
dbkerley 02-16-2012 08:24 PM
Mine is holding up quite well compared to others of the same vintage.
