-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   I need some help regarding gauges (https://www.offshoreonly.com/forums/formula/270990-i-need-some-help-regarding-gauges.html)
Monaco20 02-19-2012 02:53 PM
Hi guys
I would like to replace my orignal guges in my 242SS
I am thinking of Livorsi mega gauges
My boat is in winterized at the moment and I do not have
the possibilty to check the diameter and sizes of the original gauges.
Any one know if it is plug and play with my Mercruiser
454 330 Hp Gen V and what sizes I should order from
Livorsi. Also what do I need to buy to get every thing running with my engine?
Info asp will be appreciated, have a change to join a transport to Norway end of next week :-)
Mach 1 02-19-2012 03:39 PM
I can't comment on the gauge sizes as I don't know but if you replace your gauges with Livorsi you will need to buy new sending units as the Merc sending units are not compatible with Livorsi gauges.
DiamondPerformance 02-19-2012 03:46 PM
Merc sending units are compatible with Livorsi gauges. Your gauge size is 3-3/8" for the tach and speedo and 2-1/16" for the smaller gauges. Let me know if i can help with an order.
Bill
Monaco20 02-19-2012 04:51 PM
Bill
Hi Bill
I also thought that the merc sending units where copatible
good to get this confirmed,
I have seen som 5 gauges kits (Mega series) do you also
offer this? I am also consider Speedo, triim meter and deutsch connectors
Further I am considering to change my stock exhaust system. I checked your web page and saw that you
have a offer on a Emi system
Send me a mail with your phone number maybe we can do some business
Best regards
Rune
Mach 1 02-19-2012 11:08 PM
I apologize if I gave you wrong information. When I upgraded I was told they weren't compatible. Guess I got taken....
DiamondPerformance 02-20-2012 07:23 AM
Auto Meter gauges you need to change senders, Livorsi you will be fine.
Rossman40 02-20-2012 11:08 AM
Send me your email, I had the exact same guages put in my 242LS last year, turned out really nice. I will email you some pics
tpenfield 02-22-2012 06:56 PM
242SS Gauges . . .
Originally Posted by Monaco20 (Post 3621453)
Hi guys
I have a 242SS (1991 model) they came with VDO "Blue Line" gauges. So, the senders will most likely be VDO brand to match. You can get a VDO catalog online and check the dimensions. Just checking my copy of the catalog, they had 52 mm and 85 mm sizes as the cut-out holes. The 85 mm were for the speedometer and the tachometer.. The rest were the 52 mm.
There is also a 100 mm size, but based on my measurements, it was not used on the 242SS.
Jeff H 02-23-2012 08:38 PM
You will need to replace the fuel level sender with the livorsi.
get the float style. The VDO sender was the wrong resitance for the Livorsi. I replaced all my guages last year and almost ran out of gas with the guage showing 5/8 tank. All other guages worked fine with the stock senders.
on my "97" 382 the VDO's were larger than the standard guage dia and smaller than monster guages. so I went with the Monster guages. I think they look better and a blind person in the back seat could read them.
jeff H
formula370ss 02-24-2012 09:06 AM
Would you happen to know the actual size of your VDO guages out of your 97' Formula. I own a 01' 370SS that also has the factory original flush mount VDO guages and I'm looking to upgrade my dash as well. I want to re-use my original dash plates so I was thinking maybe I could double up the bezels to make a new guage fit ???? I'm looking into guages from Hardin Marine
