242 LS Prop
I just wanted to see what people suggest for best top end, speed, propeller for a 242 ls that has a single 350 alpha gen 1. I have a 17 pitch SS now and looking to upgrade. Any suggestions? I think this is the best one for now and im getting mid/low 40's. Let me know if I can do better. Any help is better help!
What rpms are you at at full throttle?
Originally Posted by srdrago
(Post 3660142)
I agree with aquaforce. I had a 19 mirage on my 242 SS with a 350 mag and it was to much prop, I could only get 4200 rpms out of it.
Srdrago,
This thread posts many prop pitches/RPMs/speeds: 242 Speeds Mine came (from prev owner) with twin stock 350s with Rochester 2 barrel carbs (260HP ea I believe). *It came with these: Mirage Plus, Part #:48-13700: Dia: 15 1/4.* Pitch: 19.* Blades: 3 I got only 4200 RPM due to the large diameter of the props. *See this thread for more details. I replaced them with new Mercury Quicksilver Lightspeed (replaces Laser II) props, Part #: QS5072X.* Dia: 13 7/8 Pitch: 21 Blades: 3 I picked up 200-300 RPM and 2-4 MPH. * The next step was replacing the intakes, moving to 4 barrel 650 CFM carbs, and thru hull exhaust. *With the Quicksilvers, I got about 5100 RPM (58.6 gps). I later tried 21P Mirage Plus props, but that was too much prop. |
I am hitting around 4400 RPM with a 17 pitch
(Post 3661388)
| All times are GMT -5. The time now is 01:53 PM. |
