-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   ski tow eye or pole for 312 Fastech (https://www.offshoreonly.com/forums/formula/276048-ski-tow-eye-pole-312-fastech.html)
silent lucidity 05-08-2012 11:26 AM
Hey Bird owners have any of you added a ski tow eye on the back of your 312 or similar?? my little girl likes to tube nothing fancy just straight. My boat pulls it up fine but hooking a lines to the rear strap points sucks and pulls the tube down rather than up... I know-I know.... this isn't a ski boat...but I do what my 8 year old wants what can I say... Any thoughts?
PhantomChaos 05-08-2012 12:15 PM
Why not add a provision like this.......with a backing plate.
http://www.gandermountain.com/modper...ID=GSHOP_11898
97FASTech 05-08-2012 02:06 PM
Mines a 271, but maybe this will help. Behind the lift actuator is a steel plate the ski hook is mounted to.
08 fastech 292 05-08-2012 02:29 PM
I took an 8 ft. length of 3/4" nylon rope and braided loops on each end to form a bridle that I attach to the rear cleats. Works fine for tubing' behind my 292.
sprink58 05-08-2012 02:40 PM
+1 That's what I have always done...just get a ski bridle with a swivel float and you are good to go.:evilb:
looseconnection 05-08-2012 03:23 PM
I bet your deaf after you get drug behind this for a while.
LC
Shag555 05-08-2012 03:23 PM
What Sprink & Fastech said - works great... Don't succumb to buy one with metal quick connects - it'll scratch up your cleats!
aquaforce 05-08-2012 04:00 PM
LC
Huh, what did you say.... I didn't hear you :lolhit: :lolhit:
I'm hoping my silent thunder will be OK in that regard.
aquaforce 05-08-2012 04:13 PM
Hanging a bridle off the cleats is a quick easy. If you want to make the boat tow eye equipped then the same way Formula did the 271 and my 242 would be just like original equipment and look good.
silent lucidity 05-08-2012 04:37 PM
Thanks bird owners,,, never thouht about the rear cleats.
Will have to make my own bridel so's not to rub on the paint anywhere.. a scratch and I KILLLLL YOU! :lolhit:
