I drove Dougs 233 last season and with a 454Mag and a Bravo best it ever ran was low 50s and we tried 3 different props.
Originally Posted by sprink58
(Post 3744145)
You definitely have a prop issue if you are only getting 50 and your WOT RPM should be around 4800. Formulas run best with a bit of bow up. As you get used to the boat you will get a feel for what drive and tab angle works best for the way you are loaded.
I'm guessing ideally with a light load and properly trimmed with a 23" tuned prop that rig should see 60 plus. Those boats with twin 260/350 Chevy's see 65 on any given day. |
Originally Posted by HTRDLNCN
(Post 3750346)
My 233LS was an 81 and ran about 45 with a 260hp small block. I'd gues with a 350hp big block, you should be around 10mph faster? That hull has a seriously deep V which makes anything less than 8ft'rs reasonable water and the bravo will stand up to the air time alright for sure. The down side of the real deep V, is a little less speed. I know my current Baja is about the same length but a shallower V and a 454/alpha. She runs right at 60 with a 1.36 ratio outdrive spinning a 19P cleaver. You likely have a 1.5 ratio, and you want your engine at the 4600-4800rpm range maxed out. So... My guess would be a 21P prop with some added cup to carry the bow. Sprink is right, the Formula's (especially yours) like to have some bow lift.
(Post 3750411)
Who is Doug and what year is his 233?
1967 |
That is a beautiful classic 'bird. Good luck with it and what sounds like the pending restoration work. Keep us all posted on the progress.
Sprink-Looking through that brochure brought back some very old memories looking through Formula brochures when I was a kid and dreaming of the day when I would be able to own one. Thanks for posting! Dave |
Thanks for all the info so far guys. I'm getting to know the boat better and starting to work on it as the season wines down. I have another, what I hope is a basic question.
I noticed that the prop is kind of stiff to spin while in neutral on the trailer. Spinning in reverse seems a little easier but still stiff. When i spin it forward it is kind of hard to spin (one hand) and seems like it kind of gets stuck, then i can shake it or let go and then I can spin it again. I didn't try spinning in gear. The boat runs and shifts just fine, both forward and reverse (sometimes it wont come all the way out of forward to neutral with out giving a little extra pull back on the shifter). I have only spun a Alpha 1 by hand so I dont now how the Bravo's feel. I did take the prop off at one point, maybe I put it on too tight? Thoughts/suggestions? Is this normal? Maybe this should be a new thread. Thanks again. Dean |
| All times are GMT -5. The time now is 03:37 AM. |
