-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Anyone running Merc Maximus Prop's (https://www.offshoreonly.com/forums/formula/283885-anyone-running-merc-maximus-props.html)
paaka937 08-30-2012 11:02 PM
Just wondering if anyone is running Merc Maximus prop's on their formulas and what kind of difference you are seeing between those and the Bravo I's/Mirage?
If you are tell us what boat/engines and what changes you are seeing in performance/top speed/handling/fuel economy if any?
Thanks and happy boating.
FIXX 08-30-2012 11:49 PM
fixx
my friend jeff ran a set of 26's on his 1997 312..300 hp 454's mpi's with 1.65 ratio drives..he was running 28 bravo ones..the fastest with the bravoe he said it ran 67 mph,with the 5 MAXIMUS THE BOAT RAN LIKE 62 MPH..the boat would plane off at 2800 rmp's and stay on plane around 1900 @ 20 mph...he would also use 1/3rd lass fuel over the 28 bravo props..he still has the props but traded in the boat at shoegrens..
BONDO10 08-31-2012 06:46 AM
I have both. 2004 382 Fastech.28 Bravos and 26 Maximus.Both tuned and labbed by Bblades. The 5 blades help getting on plane,and cruise is much better,but top end suffers.I run the 28 four blades all the time.382 is a heavy boat,and the fives just have too much bite.The fours are certainly easier on drives. All depends on how you boat I guess. I had a 312 with 496's 375 hp,and always ran four blades.Boat planed fine,never really thought about fives for it.
FIXX 08-31-2012 07:33 PM
fixx
did you get the rubber plug kit for the props and have you played with them to air out the props?
FIXX 08-31-2012 07:36 PM
fixx
BTW reguargd to your im,,if your running mirage 3 blades on your boat and its hard to get on plane its because of the mirage props..4 blades are night and day and the 5 blades are even better..my friend wants to sell his maximus props..
