-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Winter project 292 88' Remove hook (https://www.offshoreonly.com/forums/formula/287928-winter-project-292-88-remove-hook.html)
Dtile 11-18-2012 08:24 PM
Im thinking of removing the hook on my 88' 292. Anyone try this yet? Any results? I have heard it is put in there to make the boat "slower" for insurance purposes. Myth? I do see thehoook take about 1 inch of flat surface away from last 3 feet of bottom near transom. Had a friend always buy new Checkmates and that was the first thing he removed, sweared they made the boat faster. Any thoughts? Also would like to gelcoat transom since i removed slient thunder. Formula have a special color/they sell it?
Much appreciated. mike
[email protected] 11-19-2012 05:44 PM
I would love to see the results of this. I have heard that the boat will purpose. I don't know. I know that my 271 has a lot of hook. Call Scott at Formula. I believe it Imron 088 white. Good luck and keep us posted.
Crude Intentions 11-20-2012 02:25 PM
Curious to see myself. Thinking of removing my hook on my 272
38fountainecman 11-20-2012 03:42 PM
I had a 1990 for seven years and I'd be carefull removing the hook. Mine seemed somewhat "flighty" with the hook. Certainly you will have less wetted surface with the hook removed and that should result in speed. I guess as long as you use your k-planes accordingly, you can control any porposing issues that might result. One of my favorite boats was my 292 SR1, a timeless classic. You might want to also look at extension boxes, although a lot more costly than removing the hook.
formula 382 sr-1 11-20-2012 05:08 PM
The 272 we had we took the hook 4 ft forward. It did not look to us that you could grind it out. You can see it from the inside of the bilge. I don't know if it helped or not we did so much to at one time from alpha to bravos bennet tabs to K planes new motors moved the hook forward but it cant hurt.:whistle::whistle:
smokin' gun 11-20-2012 05:11 PM
been done already .waste of time
mthammer 02-17-2013 03:27 PM
i have a 1990 272 took them off last summer waste of time gained 1/2 mph
shekmark 02-17-2013 05:09 PM
Can someone explain the hook to me. Just bought a 242. I can't picture what your talking about. Thanks
