-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   What is the stock prop for 330hp B1 with 1:50 ratio????? (https://www.offshoreonly.com/forums/formula/288679-what-stock-prop-330hp-b1-1-50-ratio.html)
aquaforce 12-09-2012 07:17 PM
I was thinking that the stock prop for the 330HP B1 and 1:5 gear was a Miriage SS three blade 15 1/4 X 19P, right hand, is that right?
Tell me if I'm wrong because that is what I need a prop for.
Anyone have a prop laying around for this set up?
I am going to put stock power back in my 242SS. The prop was missing from the power package when I got there to pick it up and I sold the prop off my boat thinking I was going to stroke it up and use a larger wheel. Now that I have scrapped that idea I need the original prop back. :poopoo:
c_deezy 12-09-2012 08:28 PM
I have a Mirage Plus 23P in the swap shop if you are interested. It's been re-conditioned but looks pretty good. It's what I used before I raised my x-dimension. Similar hull, with the same motor/drive.
88242LS 12-09-2012 08:29 PM
your gonna want a mirage 21
86242ls 12-09-2012 08:44 PM
21 mirage plus will be what you want. 23 will be a little much for stock power.
86242ls 12-09-2012 08:50 PM
I have a 19p mirage plus if your set on this prop I ran it with my 242 when it had the small block in it and alpha one, I ran a 23 plus with my bravo swap and 509 and currently run a 21 plus with my 454 with that has some where in the area of 365-400 hp.
aquaforce 12-10-2012 08:08 AM
Thanks but I don't think this 330hp will pull that wheel.
I heard some ran the 21. I'm not sure how to tell if that would work. This 242SS had a 19 when I got it.
I'm open for more pitch but 19 is what it had when I got it so I'm thinking to start there. What do you want for that 19?
86242ls 12-10-2012 10:08 AM
if you pm me your email I can get some pictures to you by the weekend of the 19 plus. The 21 plus I run on the boat now really works nice I cruise at 30 mph at 3000 and have reached speeds of 62 mph at 4900 which is the max I can pull out of this motor all through gps speedo . Pretty much the same hull just different interior config....
aquaforce 12-10-2012 11:38 AM
Pm sent
boilerdaddy 12-10-2012 03:13 PM
Yep, the 21" is the one you want. Check out Formulaboatsforum.com.
aquaforce 12-10-2012 07:25 PM
Sweet. I replied over there too.
aquaforce 12-10-2012 07:26 PM
Ok so scratch the 19.
I need a 21 y'all. :lolhit:
So a stock Bravo1 single installation is RH rotation right?
I have a 26P Bravo1 LH four blade to trade for a good Mirage Plus, RH, 21P.
DRock 12-13-2012 01:01 PM
I run a 19P Rev 4 4-Blade prop on my 89' 242SS (stock power) and love it! The down pitch equalizes out with 4 blades and you get a great hole shot and more importantly (to me that is) lower planing speed... Lost 2-3 mph top end, but I personally don't drive around on full throttle all day so made no difference to me, especially when the stock 242ss is no rocketship to begin with
aquaforce 12-15-2012 07:40 PM
Thanks for that info. Do I understand right that the Rev4 is supposed to be better than the Bravo1 prop? I am expecting to run my Bravo1's on my LS but I might have to take a look at the Rev4 lineup.
