272 vs 271
What's the basic difference between these two models?
Huge difference. Almost 3 foot and one engine vs 2.
I have always thought of the 271 as the older 242 put on steroids . . . Only about 1 foot difference on the 'usable' part of the hull . . .
The 272 from the late-80's - early 90's is more like the 292 of today in terms of size, power, etc. So, if you put a 271 next to a 272 (w/silent thunder platform) the 272 will be about 2 feet longer, a few inches more narrow, 1,000 +/- lbs heavier. |
Originally Posted by t500hps
(Post 3883368)
Originally Posted by 86242ls
(Post 3883647)
forgot the almighty stepped hull
These guys nailed both very good boats, buddy has a 272, when i had the 271 he was about exactly 2 ft longer, both have really strong points, and great arguments for each, I loved our 271, rode great and performed pretty well, you could go swimming in the engine compartment compared to most boats, which made maintenance a breeze
So what I am reading is that a mid '80's~early '90's 272 is the same size as today's 292 and the 242 from the same era is equivalent in size to the 271....correct?
Originally Posted by sprink58
(Post 3883877)
If the swim platform is NOT molded onto the hull (ie: bolted on) than it is NOT included in the LOA.
If the swim platform is molded onto the hull, than it IS included in the LOA. Most newer Formulas are this way. |
Originally Posted by Chart
(Post 3883941)
If the swim platform is molded onto the hull, than it IS included in the LOA. Most newer Formulas are this way. Sounds like this deal really helps the marinas...they have a cut off in their pricing usually at 26'. So a guy with a 242 pays less than the owner of th 271...and they take up the same space. The Bahamas have a 26' premium also I believe. |
The mid 80's early 90;s 272 is alot more boat then a 292 fastech. I have owned them both. 272 was a great boat
(Post 3883941)
Originally Posted by oh6662b
(Post 3883996)
Brian |
Originally Posted by befu
(Post 3884041)
OK, someday I have to look at one of these. I have heard this before, but am surprised by it. They are longer, even with the swim platform by about 6" or so. They are wider by 6" or so. they are heavier by about 1200 lbs or so. Yet everyone says the 272 has more room. Some day I will find someone with one up in south west Michigan area.
Brian |
fixx
(Post 3884090)
What is equally amazing is in comparing my 255 to a 272....the 272 seems to be 7/8 the size of the 255!! I have owned both now but I didn't become aware of the difference until I was out on Diego's 272 SR-1. The 255 Liberator has a deeper cockpit higher freeboard by 12" and a bit more head room in the cabin. The difference becomes very obvious when you walk past both boats while they are on trailers.
Originally Posted by mrfixxall
(Post 3884129)
john,if you measure your boat its like 27'2'' or 29' 2'' i forget..i remember back then they measured the boat on the inside??
you know what I'm talking about. |
| All times are GMT -5. The time now is 11:10 AM. |
