-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Fresh water pump (https://www.offshoreonly.com/forums/formula/296749-fresh-water-pump.html)
FANTAZ28 05-20-2013 09:11 PM
Fresh water pump
Finally got my 353 out and had a question on the fresh water pump. I put water in the holding tank, flipped the switch hear the motor running but im getting next to no pressure at the sink just very little water trickling! The vacuflush toilet is getting no water as well!
Am i missing a valve some where? or is the pump just bad?
353Formula 05-21-2013 07:01 AM
Probably the pump I just fixed mine cost on the pump was 83 mine was doing the same thing
FANTAZ28 05-21-2013 10:10 AM
where did you buy it from? i need to get one asap otherwise the bathroom is INOP.
Didn't see you out sunday? steve said you were out and about
86242ls 05-21-2013 11:02 AM
He said he passed us a few times, we just didn't see him, he was going so fast!!!!!!!! LMFAO!!!!!
FANTAZ28 05-21-2013 11:03 AM
i believe it!
353Formula 05-21-2013 05:20 PM
I got it from west marine was 135. Direct replacement
FANTAZ28 05-21-2013 05:24 PM
is it just a standard pump? or do you have a part number or something?
353Formula 05-21-2013 05:24 PM
I was working on a beak boat then I was trying to catch up with you can't keep up with a 78mph 353
I am going to take my power out and put some 502s in. Lol
FANTAZ28 06-09-2013 07:27 PM
Alright so I changed the pump. Now the pump will run NON stop and whats strange is only got pressure at the sink for a limited time? Very little water to the vacuflush as well. Can the system be air logged? i only had a few gallons of water in the tank but i figured that should be plenty
oh6662b 06-10-2013 04:25 PM
Check the filter sounds like what mine did when it was plugged
FANTAZ28 06-10-2013 07:51 PM
It was clogged and i cleaned it before putting on the new pump but i'll check again, maybe there is some **** in the tank that keeps clogging it
