formula letters fell off
some of my "FORMULA" letters have fallen off, most likely because someone put a bumper over them and age. I have the letters, anyone have any ideas as to the best way to re-attach them. were talking the chromed plastic letters.
Thanks DD |
My letters need replacing also where did you get them??
mine need replacing also.
Any Formula dealer should have them, that's where I got them when I needed a couple of them, if not e-mail or call Formula and I'm sure they can hook you guys up.
They have sticky rubber on the back and you just peel the white paper off and stick on, but be careful, they're hard to get back off, so get them on right the first time.................easy. |
I have my letters, i didn't lose them. just have to figure out how to get them back on. the original sticky stuff is not an option.
the reason i want to put the old ones back on is cost. you can usually find them on ebay but they're pretty pricy. If memory serves me correctly over $20 each. not bad if you just need one but if you need a lot its pricey. they also have the emblem available if you need those. if anyone knows how to re-attach the old ones let me know. Dennis |
Any auto parts or auto paint supply place will have 3M emblem adhesive. Also comes in a tape version. The tape is easier to use.
1/2" 3M Trim adhesive
The emblems are attached with automotive double sided tape. If you are reattaching your original emblems all the old tape and adhesive need to be removed before installing the new double sided tape. The tape is available at any automotive paint store. I would not use the trim adhesive or emblem glue. Jeff Wurl
I have heard of people using 5200 to attach them.
| All times are GMT -5. The time now is 10:44 PM. |
