GPS Measured 330SS Speeds with 496Mags
First good day with the boat working well, so we got the GPS going and burned some gas.
Load was full fuel, first mate and I and our long weekend load of clothing, food, etc. RPM Speed in MPH 3000 33 3200 35 3400 40 3600 42 3800 45 4000 48 4200 50 4400 53 4600 56 4800 58 Top Speed 60.0 Top speed was obtained later as we burned gas down and got lighter. I had to really work it, but we got an honest GPS measured 60 out of the boat. Fuel Burn We don't have a fuel flow meter, but we ran from Elk Rapids to Charlevoix and back in total time of just about exactly two hours and varying speeds on the way up measuring with the GPS. About half the way up and back was cruising at 3400 or so. The other half on the way back was wide open to get the all-important 60. We burned just over 75 gallons in the two hours. I had expected worse! Cheers! |
Sounds like ya'll had a good time.. Your rpms is right at the top on the mags which is good.. what Props are you running??
I would have to guess using 23p? based on 1.5 drives.. that puts you at 13.9% slip at wot and more importantly 18.9% slip @ cruise. both seem high. if, 22p would be a little better at wot but still not good at cruise... 15.2% cruise and 10% at WOT.. Either way, you can probably gain more mph and better fuel efficiency with a lower slip at cruise with some prop work and/or testing.. I am a lil over propped (with this head anyway) and although its a different boat (yours is wider and heavier), I am getting 9% cruise with 25p m+'s. I also need to get either some the 3 blades worked or try some 4 blades.. (want more on a hi cruise.. ie. 4k as opposed to the family cruise speed at 3400. |
I think we are running 23 props, but I'll have to check when we haul out in a few days to be sure. I had the props all reconditioned last fall since they were a bit chewed up when we bought the boat last year.
I'd love a few more MPH at cruise and WOT, but the first mate is balking at the cost for four props! Thank you for the insight. I'm still on the steep end of the learning curve on this stuff and had hoped someone might be able to share this kind of info! Cheers |
Give BBlades a call and see what their suggestions are. Really nice to work with and will save you a ton on prop testing. They may be able to tweak what you have.
Thanks Cig. I might have to do that!
Now, anyone got any tips on how to convince the family 'Woman Inquiring about Family Expenditures' it is a needed upgrade? |
Originally Posted by glboatdriver
(Post 3946897)
Now, anyone got any tips on how to convince the family 'Woman Inquiring about Family Expenditures' it is a needed upgrade? The boat will be more fuel efficient and we can go out more often for less money....which is truth, fact and real anyway!!. |
Originally Posted by nailit
(Post 3946617)
I would have to guess using 23p? based on 1.5 drives.. that puts you at 13.9% slip at wot and more importantly 18.9% slip @ cruise. both seem high. if, 22p would be a little better at wot but still not good at cruise... 15.2% cruise and 10% at WOT.. Either way, you can probably gain more mph and better fuel efficiency with a lower slip at cruise with some prop work and/or testing.. I am a lil over propped (with this head anyway) and although its a different boat (yours is wider and heavier), I am getting 9% cruise with 25p m+'s. I also need to get either some the 3 blades worked or try some 4 blades.. (want more on a hi cruise.. ie. 4k as opposed to the family cruise speed at 3400. I looked at the boat build sheet and it looks like it says 2.0 drives. Would this make more sense rather than the 1.5? |
| All times are GMT -5. The time now is 08:25 AM. |
