New to me 382: need help on best prop / spin in vs. out...
After years in a 370 and reading the posts here about the fastechs I had to bite the bullet and grab a 382... The question now is whether or not it is propped perfectly and if I should continue to spin the props out from top dead center or in. I have read the threads and unfortunately they seem to contradict each other from time to time (go figure)... I would love to get the current final answer on what prop to use with this setup from those of you that have experience... Here is the case... (pics to follow tomorrow)
2001 fastech 500 EFI 's stock 275 hours Bravo 1X drives on boxes No gen Has a/c Currently running 28 pitch bravo non labbed spinning out. Getting roughly 5100 @ 71-72mph Could possibly pull better numbers, I've only been at the helm for a day and I am sure that there is some driver error in there... Questions are... What prop? Labbed or non? 4 or 5 blade? In or out? I appreciate any help....... |
Stick with the 4 blade 28's. easier on drives. Send them to Bret at Bblades and have them labbed.Got me a few mph.71-72 with 500's ,gen,and a/c is pretty good.Enjoy
I had my 2002 382 running 98 at one point and never owned it with stock motors........but 71-72 sounds about right w/ 500's. I agree, stick with 28's. Mine did great on 4 blades (34's) but started blowing drives on 5 blades.
edit: Mine spun "out", never tried "in" since my previous 312 didn't dock well spinning "in". |
Thanks guys. Any opinion on spinning in vs. out?
I would say keep them spinning out from a docking standpoint. I had the props turning in on my old 357 and didn't notice any chage at all other than it made docking a real pain in the ass.
Originally Posted by croaker
(Post 3950459)
Originally Posted by jriggs
(Post 3950539)
Spinning in is bad for docking? Tell me how that is? My 357 seemed a little less nimble than I expected, after driving a 382 that spun out, and I wondered what was causing it. The steering is stock and seems to be very floppy and free behind the boat, with no external rams, but what I felt didn't seem to come from steering; still it didn't seem to move as well as expected. What is different with "in" VS "out" at the dock? |
I have a 2000 w/500 EFI's and I also run 28's spinning out and have seen 74 at 5300 rpm's. I have A/C no Gen
Originally Posted by J.B. Marshall
(Post 3950846)
Thanks |
Are there any quick and relatively easy / cost effective ways to grab a few top end mph with this setup? What has worked and what has been a flop? I would like to see high 70`s almost 80...
Advice would be great before put $$$ in dumb stuff... Thanks |
The boat will run faster with them spinning in (2-3) mph and in my view, a little better overall. Spinning out lifts the stern and pushes the bow down. Spinning in sucks the stern down, lifting the bow.
You will lose some handling around the dock as they cant leverage off each other as much as they can when spinning out. No question that docking becomes a little more difficult, especially in wind or I imagine, tide. I just dock it like it is a big single and all is good. MY recommendation is to first swap the props as it costs you nothing and then give Bblades a call. They know their stuff. |
You want 7-8 more mph.......your going into the engines to get it (or gutting the entire cabin to reduce weight).
540's or cam/heads bigger intake or both :) Keep in mind: Another guy with your setup said he saw 74....once. |
All I can comment on is my own personal experience... My 382 has AC, Gen, Bravo drives / 525 SC motors that have been rebuilt and dyno 575 hp per side. Spinning labbed 28 p Bravo 1 four blades I have seen 80 mph on GPS at 5300 (best I have seen), and can run 77 - 78 mph any day. I am currently running a set of labbed (BBlades) 30 pitch bravo's which have improved my crusing speed to 55 mph at 3400/3500 rpm and no change in top speed other than I can only spin them to 4900 rpm.
As for spinning the props in, you loose the ability to spin the boat around when docking....it is like the two props fight each other when you put 1 in fwd and 1 in reverse. The boat just sits there and does nothing. Just my $0.02. |
My 382 was already set up with Stellings and stock 28 Bravos spinning in. I really like the way it carries the nose and wake is flatter too. A little slower to respond in tight ares with windy conditions but can be anticipated/managed with some experience.
Originally Posted by RedDog382
(Post 3952249)
How much HP per side, and what speeds and RPM? I think you told me 540's and 83 MPH, but I don't remeber so go any more...... |
(Post 3952518)
Chris,
What will labbing my 28`s do? I was told top end of 2mph +/- s... does that seem realistic?
(Post 3956788)
I own two 382's both fastech's. The 99 502's stock,26 Bravo ones labbed by b blades 70 gps. Props were turning in when I bought the boat. I couldn't back that thing into a slip for nothin'. Son in law was giving me a hard time I gave him the helm, he didn't have any more luck. Turned the wheels out, whole new boat. Not quite as fast but I know where it's going when I'm backing up. The 2000 600 Volvo's in front of Bravo XR's on Stelling's boxes I have only driven with props turning in. 28 Maximus labbed by t500hps, Gen & Air 78-80 gps. My 99 is for sale & a really nice boat!.
Thanks for posting that info Apexwarrior
With my mono hull "in" is where they are and sounds like that is the best thing for this boat anyway. I'll be doomed at the dock for a while.:poopoo: I noticed how the boat moved so little compared to an "out" spinning 382. It is going to take me a while to figure a method for this "in" spin on my TRS. I was wondering what I would get by spinning these TRS out and this posted info pretty much answers that. They will stay as is and I'll just have to deal with it. |
Thanks everyone for the advice. Saw 72 on GPS last weekend, getting the props labbed this week,we'll see if that helps...
Originally Posted by $hredder
(Post 3958247)
Hey $hredder, clean out your PM box! |
Done
| All times are GMT -5. The time now is 01:25 AM. |
