-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Gas gauge trouble (https://www.offshoreonly.com/forums/formula/303410-gas-gauge-trouble.html)
whistler 09-25-2013 06:32 AM
Gas gauge trouble
The gauge on my 382 is stuck at 3/8's. Reads the same on the dial and digitally. Tanks been full and less then a 1/4 since problem started with no movement. Any suggestions?
314joey 09-25-2013 07:44 AM
Check the ground wire.
axapowell 09-25-2013 06:55 PM
Sounds like the sender. Check the breaker under the rear seat. It may have been bumped.
Dave
whistler 09-27-2013 06:11 AM
I checked those before. I'll check them again. Thanks
So many wires. I didn't realize you needed to be an electrician to own one of these
whistler 09-30-2013 07:43 AM
Fuses ok. Manuals not much help in tracing grnd wire. How do I reach the sender coming out of tank?
