-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   382 gas tank access (https://www.offshoreonly.com/forums/formula/304695-382-gas-tank-access.html)
whistler 10-28-2013 03:23 PM
382 gas tank access
Where is the access panel to the sending unit for the gas tank? Fuel gauge stopped working
slickwilly382 10-28-2013 03:40 PM
its located right under the rear seat. which is fiberglass I had to cut a hole to get my sender out.
RT930turbo 10-29-2013 01:12 PM
I have a panel that is screwed down under the back seat. 6 or so screws and plenty I access I the top of the tank.
C_Spray 10-29-2013 06:56 PM
Same here; a handful of screws, and there it is. Sr-1's must be different.
whistler 11-01-2013 06:55 AM
Thank you.
