i had a similar issue i thought was electrical....changed sending units even went as far a running a new wire from the sender to the gauge.....my engine builder told me to add oil to the very full mark on the dipstick....and it all went away...he felt the pan was getting sucked almost dry and the oil wasn't returning back fast enough...so i keep all my marine engines at the very full mark now :)
if you want to add the mech gauge, the oil pressure alarm sender is mounted at the top of the block on the rear of the motor .....right below the Distributor near the PS cooler ....you could add a T there and keep the alarm and add the Gauge ... I did that on my 311 and just mounted the gauge under the hatch .....m
1/8 pipe thread ..... |
Originally Posted by Wally
(Post 4025748)
Originally Posted by offthefront
(Post 4026157)
(Post 4026157)
Originally Posted by RedDog382
(Post 4027109)
Seems like that would pretty hard to monitor at 70 mph ... :)
Well the issue I was having was the pressure would go to almost zero with Hot Oil at Idle .....So I could just crack the Hatch and check ..... it was actually about 20lbs when the electric gauge would be at zero ..... I have just put it on the rear seat to check while running .... :cool: |
Check for loose belt as well
Originally Posted by Secret Formula
(Post 4027620)
I've heard that a common problem in those year fastechs is that all the pink in the graphics and interior make for a loose nut behind the wheel!! Sr1's have more fun!!!
J/K!!!! |
Originally Posted by 86242ls
(Post 4028147)
J/K!!!! |
| All times are GMT -5. The time now is 04:31 PM. |
