-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Replace a 350 mag with a 496 mag ho (https://www.offshoreonly.com/forums/formula/309198-replace-350-mag-496-mag-ho.html)
usmcsrt1 03-02-2014 12:11 AM
I have an 88 Formula F223LS with a stock mercury 350. Will a 496 MAG HO drop in without any major modifications? Will the stock Alpha 1 handle the additional power? I'm topping out at about 45gps mph now. Will I notice a significant difference with this upgrade?
Thanks,
Rich
Crude Intentions 03-02-2014 12:54 AM
The alpha will not hold behind it. The alpha would blow frequently behind a 454/330.
79formula 03-02-2014 11:43 AM
I would just freshen up the 350. New rings, bearings, gaskets, Vortec heads, a decent cam, performer intake, holley carb, and make 400hp. I went from 55mph to 67mph on GPS all for less than $2000. An alpha will live no problem behind a hopped up small block, they make alot less torque. Torque kills alphas.
79formula 03-02-2014 11:44 AM
I would say 45mph out of a 350, the 350 is tired.
86242ls 03-02-2014 12:43 PM
an alpha with a 330 would live for a while as most of these boats that came with a 330 from the factory had alpha ones, I wouldn't bother pouring money into the 350 as you will not see any real gains. I tried that with my old 242 going from a 260/350 to a 350 vortec roller motor with a nice valve train est 400+ hp and went from about 44 mph to 52. I then went to a big block set up 509 c.i. with an alpha and went in the mid 60s with it for a season before upgrading to a bravo set up, removed the alpha still working and sold it. going from a sbc to bbc would probably net you a solid 10+ mph going with a 330..
Crude Intentions 03-02-2014 12:58 PM
The alpha will not live long behind a big block. They did this in 87 and quickly designed the bravo because of so many issues. 87 and some 88s for the most part had the alpha behind a big block. It was always an issue. As with anything else there are ways to help something live longer but an alpha isn't meant for big block torque.
Secret Formula 03-03-2014 09:59 AM
Reman Bravo 1 is $3K. It's worth it.
302 03-05-2014 06:35 PM
Rebuilding the 350 is your best bet. A new big block and B1 out drive is going to be over 10K, and undoubtedly there will be more expenses once the install begins. That is a lot of coin for the speed you will see.
If your tired 350 is pushing you to 45, a fresh and built 350 (and you can buy a crank that will make it a 383) could probably get you low to mid 60's depending on prop and water conditions.
