Need advise on Formula 272 SR1 Thanks
I am going today to test run this boat. From what I am seeing on NADA the boat is not worth the asking price. Anything I should look for?
Thanks,
http://smd.craigslist.org/boa/4399581715.html
Thanks,
The boat looks to be in nice shape. If it really is, along with the trailer I think 17-19K is realistic so he isn't too high if he's willing to negotiate. Check the gimbals, they tend to be worn if original and are pricey and a pain to fix.
21 and 42 footers
NADA on that old a Formula isn't much to go on. If totally mint it could be worth that. Since there is almost always some minor issue with a boat that old I agree with the above. For what appears to be a good/clean boat I wouldn't expect to get it for $15K but you should get a little something off $21K
Ok so NADA isnt a rule on these... I have seen the boat previously its clean but the bottom of the drives both have Skeg guards on them which I was not thrilled about... steering helm is loose... Platform has had fiberglass work as well as rub rail, cables for bolsters have been removed. Mechanically it appears sound.
After looking at it yourself for aesthetics and general condition, be sure and get the Survey completed. Survey is money will spent or invested or saved, depending on the results. Formulas are very nice boats and built well, but all boats have problem areas after so many years. Good Luck!!
Yeah I have my mechanic (father) going with me today on the test run... He is a certified Mercruiser mechanic and been in boats for 50+ years... Just wondering if there was something in particular we should look at... I hear the (silent thunder) platforms rot
There is also one for sale in Massachusetts for $21K . . . but has not sold at that price, since last Fall.. NADA will be a bit low on this boat. Try BUCValue.com for another reference point. I think one recently sold on this site for around $16-17K
I would check for moisture/rot in the transom, the center engine stringer and the main bulkhead. If you find moisture in the main bulkhead, then you may want to determine if there is moisture in the fuel tank bay as well.
The 272's sit very low in the water with the big engines, so something to consider.
Have a complete survey done...money we'll spent. It's good piece of mind. A transom and center stringer job alone on this boat could be $5k+ and other things always show up once into the job. Nice lookn boat, though.
I think I am gonna pass on the boat was told it ran 65-70 was barely able to run 54. Big blocks would only turn up 4k swinging 25 pitch props. I love the way the boat looks but I want something faster.
