-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Some data needed about 2002 Formula 271 Fastech? (https://www.offshoreonly.com/forums/formula/313211-some-data-needed-about-2002-formula-271-fastech.html)
Pave 08-08-2014 01:43 PM
Have not decided the place yet. Will have professional to check places on sunday. Do you have photos on yours bj1464b?
bj1464 08-08-2014 02:03 PM
Sorry no photos but you are welcome to come take a look and for sure go for a ride.
Pave 08-08-2014 02:15 PM
Might take a while, :-) could you take a photo at some point and via email?
bj1464 08-08-2014 02:17 PM
I will snap some pic's should be on boat this weekend.need your e mail
Pave 08-08-2014 02:19 PM
That would be great: paavo.puomila(at)elisanet.fi
Pave 08-22-2014 02:03 AM
Originally Posted by Pave (Post 4166191)
The leak comes from steering axel at it is getting worse. Have to take boat up everytime after running so I'm glad I have a trailer for it. So the engine has to come off and change everything from the drive bellows to shifter cables when it's open anyways.
The engine and drive are now taken off and here is what we found:
http://www.sportslace.com/thinkblue/formula3.jpg
Pave 09-11-2014 06:29 AM
Was supposed to get boat back on tuesday but there was one more problem when the water pump stopped pumping. So new pump was ordered from Belgium and my summer is finished. The winter is coming here in Finland.
Pave 02-25-2015 04:35 AM
Never put the boat back to lake after the service. Now it's already raining in Finland and snow is melting away so spring seems to be coming, :-)
I started to wonder what kind of running hours you generally get with stock 496 mag ho before you need engine repair. Mine is now 500h and no problems but is there some kind of averange number when you generally know you should open the engine?
Pave 03-03-2015 04:38 AM
Or do you just drive until something gets broken?
Pave 07-13-2015 08:16 AM
This summer has been awful here in Finland. Only 7 hours has the motor been running. There was weird noice that seemed to come from silent thunder. After few hours it stopped. Engine sound seems to be same than before but is there something that could come loose and is now in the bottom of the lake?
Also a question of the trimtab buttons. My dashboard is same as here: http://www.powerboatlistings.com/pow.../5205/formula7[1].jpg
There are trim buttons on top of the panel where are the gas and transmission handles. One of them got broken - can you still buy them somewhere? I have not been using the two separate ones lower in the dashboard and took a sparepart from there. BTW what are those separate ones supposed to do? Other is for drive trim but I use the switch in the gashandle. The lower one has a text "trailer" but I have never used it?
