-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Fastech 292 Newbie, Stupid Questions? (long boring post) (https://www.offshoreonly.com/forums/formula/316843-fastech-292-newbie-stupid-questions-long-boring-post.html)
Tedorama 08-15-2014 11:34 AM
Just purchased a 2006 292 Fastech bought sight unseen however did have a PPI done and it is very nice with only a few minor issues. It sat in my driveway for a month before I got a chance to try it out for the first time yesterday. This gave me time to look over everything and try to familiarize myself with and clean and detail everything as I tend to be a little OCD with my stuff.
I have been lurking on this site for several months as I wanted to try a powerboat as I just sold my 282 Cobalt Bow Rider as it was too wide and heavy to tow long distances here in Utah for the big lakes, 800 miles to Lake Powell and 1200 miles to Lake Havasu round trip. I finally pulled the trigger on this Formula as I like the build quality of Cobalts and have heard Formula is similar. I do sell Porsches for a living so fit and finish, as well as sound engineering are sacred to me. I only have about 50 hours total boating experience so I am still very green and learning each and every time we go out and most of the yelling and screaming at my wife and son and vice-versa have toned down quite a bit. Now on with the stupid story and questions.
I purchased this 292 up in Washington where it was used mostly on fresh water and a few times on salt water. Regardless it was run at sea level and propped for sea level as well. It has 28P Bravo 1 props with a 1.65 drive ratio and am running stock 6.2 Mercs with Corsa Captains Call Exhaust. I had called Formula as I was looking to purchase a hose adapter to connect to the factory installed fresh water flushing systems as could get zero help from any Merc dealers I had called. I purchased the adapter and asked their very helpful technical people what prop size should I be running for my altitude which is about 5000 feet plus or minus depending on which Lakes we go to around here. The got back to me and said the 292s with 6.2s we send out with 24P props to our high altitude dealers. So I thought I will try to budget for these as I need to use WDK (wife don't know) money.
Anyways, got to the Lake yesterday for our 1st time out with the 292 (no name yet, has never been, but will very soon) and could not get it out of the hole or even on plane and would not go over 15 mph on the GPS speedometer. I tried props down, tabs down, tabs up, trims up, every combination. So we just farted around the Lake for an hour with the bow to the sky, lake spray in my face from looking over the side to see what's in front of me. My wife and son looked at me like the biggest FOOL on the planet for buying this, and were screaming at me for selling the Cobalt. I tried explaining to her that we need smaller propellers for this altitude as these boats are typically set up for sea level and the Ocean. She asked how much more that's going to cost and I said a few hundred or so ;). We then beached the 292 , ate lunch, let our English Bulldog out, went for a swim and everybody was having fun again. Ever seen a 65lb. English Bulldog swim?, they don't!
So we decide after an hour of fun on the beach to take the 292 ( my wife wants to call it SLOW RIDE) out for another 30 minutes farting around the Lake and then head home. I was baffled how it would not plane out or go over 15mph and then a very dim light bulb (must have been a 12V 3W bulb) came on in my head. What if I have my wife and my 190lb. 6'1 son ride up front in the Cabin to put some weight on the bow. They moved up front with the dog, and I decided to hit it again. Trims down, Tabs down, Full Throttle! Bow is way up 15 mph, 20 mph bows is coming down, 25 mph still coming down, 30 mph bow is down, look at the GPS speedo and we are approaching 40 mph and climbing!!, Tabs up 55 mph and trimmed out I got her up to 58mph, Hallelujah!! 58 mph is topped out at 4400 rpm with very mild chop. So we figured out crew up font to start out until we get on plane and then everybody sit where they want to. After this we stayed out for 4 more hours until the sun was getting low and my wife said lets go out again soon and where can you find those high-altitude propellers. What a difference, had a fabulous time, we are all talking about the next trip, time-off, Lake Havasu, Lake Powell, and the Planet is back in balance again.
1. If I drop from 28Ps to 24Ps will this help me get out of the hole and on plane?
2. Do I still need to have the Crew up front until we get on plane?
3. Will the 24Ps allow me to pull up to 5000 rpm (redline?) and what top speed shall I expect at 5000 ft. elevation?
4. If I go down to Powell or Havasu which is 2000 to 3000 feet in elevation, do I need to get 26P props?
5. The Corsa Captains Call Exhaust which changes the from thru the Prop to thru the Hull doesn't seem to be as Nasty as it was on my Cobalt thru the Hull. I noted the Corsa tips have baffles in them, anybody remove these baffles or change to straight thu Tips?
Thanks to all those who chime in! This is a great site and I'm upping my membership and hope to be a contributor soon!
Best to All,
Ted
Expensive Date 08-15-2014 12:13 PM
I will respond in more detail later, but its one of the few boats that you have to really get in the throttles to get on plane.
97FASTech 08-15-2014 12:47 PM
Agree, even with my 271, it takes 3/4 throttle to get her going. Once bow starts dropping to level and picks a little speed back out of the sticks to half, then trim till you feel the boat "release with more speed", and stop trimming. Does not take much trim, about a 2 - 2.5 bump on your indicators, maybe 3. If you have to use your tabs to get up, this will change your order in which you apply the trim bump. Again, this is a very general description on a 271 not a 292.
Congrats on your purchase!
08 fastech 292 08-15-2014 03:22 PM
I seriously doubt props are the whole issue here. Even at altitude of 5000 feet, the boat should plane off without too much effort. If your Cobalt was not a stepped hull, you will need to get used to the fact that these boats do not have a great hole shot. As Expensive Date said it takes throttle to get going, mine needs 3,000-3,200 RPMs depending on how many people are on board and fuel load. Make sure your drives are trimmed all the way down before starting out. Tabs down will help some, but honestly I never use mine. Let the boat get fully on plane before starting to trim the drives. Again, stepped hull boats run best at neutral trim or just a tad above.
If the boat sat for a month how fresh is the fuel? Are the flame arrestors clean? Have the plugs been changed recently? I'd add fresh fuel, clean the flame arrestors, change plugs and see if that helps. You can contact BBlades an advertiser on here and demo test 24P props, he is top notch at his trade and will guide you in the right direction for prop selection.
Let me know if you have any questions.
Dave
Expensive Date 08-15-2014 08:05 PM
http://www.youtube.com/watch?v=i3_JFl6tCl8 My old boat, and my son does speak english he was saying hi to someone. Tabs down drives in, take engines to 2k let boat start to move then slide the throttles up too 4k.If props blow out(spin) back off throttles till props catch, but 292 really don't blow the props out mutch This is how they plane, once on plane bring your tabs up and trim to in most conditions nuetral. The more people you have on the boat the longer it takes, its just practice you will get it. They are hard to plane.Now mine was a little faster out of the hole because I had changed exhaust,which gave no speed inprovment but took 250lbs off the back of the boat. That made a world of difference but you will do better once you are used to her.
COOPS 08-15-2014 08:52 PM
I agree with them all. I started my sickness back into boating with a 22 mirage. It had 400 horse in a 22 ft boat. It jumped out of the hole like a jet ski.
Then it was a 26zx with a 502. It would blow out the prop 70% of the time. Constant throttle playing to get it to crest over on plane.
Now the same set up you have... Tabs don't do much in my opinion. Drives in and get her to about 3000. I can feel the props break loose and then the slip helps the motors get up in the rpms to push it up on plane. Like it has been said it is about feeling what works for your boat. If I have a boat full of people it helps to veer to one side or the other to help it get up on plane faster.
All said I think at your altitude you will need to drop to a 26p prop.
looseconnection 08-15-2014 09:36 PM
The 292 is a ***** to get on plane and leave the drives tucked till u get up to 40. If you raise drives in the 30s as soon as you get on plane you will start to bunny hop.i have 26 bravos and planning is much easier for me than others i have spoken to. I can bounce my limiters with the 26 bravos.
Tedorama 08-15-2014 11:07 PM
Thanks for all the great advice! I'll keep working til I get it. practice. practice, practice.
I'm still not sure what prop drop I need for my elevation. Formula says 24Ps for 5000 ft. on up. Will try to contact bblades for another opinion, seems 28Ps are for sea level.
Any other 292 suggestions for improvement besides K planes or full hydraulic steering?
I'm not going that route until I know this is a keeper!
Pave 08-16-2014 03:34 AM
Here is start with my 271 with single 496 mag ho (three adults and two children inside):
https://www.youtube.com/watch?v=Ohcd...ature=youtu.be
Drive down, trims down, little movement and thenn full power, :-) I get it plane even with 10 adults but then few have to go to cabin.
Pave 08-16-2014 03:41 AM
Here is another video form our testdrive last October, it was pretty cold: 0 degrees celsius..should be about 32 degrees fahrenheit? There is also ny daughter who wants to go gaster so that is what we do, :-)
http://www.youtube.com/watch?v=XXvxyCFRsII
Phazar454Mag 08-16-2014 05:21 AM
Suggest you check the position of your trim-in limit spacers in the outdrives. See what 4mulafastech wrote here: http://www.offshoreonly.com/forums/p...ml#post3838961
08 fastech 292 08-16-2014 06:30 AM
What top speed do you see with the 26's?
Made It Rain 08-16-2014 11:55 AM
I agree with Expensive Date. I had a 2007 292 and installed new exhaust (Stainless Marine) and it helped big time, it lightened the engines about 190 lbs. We boat at Lake Powell most of the time, and use the same props at Powell that we use in the Phoenix area. Lake Powell is 3600' elevation, and does take a little longer to plane out. I think the exhaust will help more than the props.
I had Formula change out the Corsa exhaust tips with baffles to Corsa tips with no baffles on my 2012 Ilmor 382, and it sounded great. Formula built my current boat with the straight tips too.
Made It Rain 08-16-2014 02:31 PM
Here is the 292's hole shot after the stainless exhaust was installed, the lighter exhaust helped.http://www.youtube.com/watch?v=dSbp8QIKNBA This is at Lake Pleasant Arizona, 1700' elevation.
looseconnection 08-16-2014 03:06 PM
In the salt i have seen 70. Fresh is 67/8 any weekend. Like i said i am in my limiters. The lab 28s do the same speed but with less rpm.
looseconnection 08-16-2014 09:43 PM
Originally Posted by stimleck (Post 4172833)
the designer needs a punch in the face
WTF are you talking about?
SB 08-17-2014 07:52 AM
Like a Kid with a stock 5.0 Mustang with Flowmasters telling a Porsche owner his car sucks cause it won't do a burnout like the Mustang does..
4mulafastech 08-17-2014 09:12 AM
My 292 has 6.2's (340 hours) with stock exhaust and I turn labbed 28's. Just a couple weeks ago we were LOADED down with 4 adults, 4 teenagers, 3 coolers, etc. and she planed out just fine. I'm at 470' elevation, have 280S K-Planes and changed my trim-in limit spacer to allow the drives to tuck in a bit more. (See post 11 for link)
I would think a nice set of labbed 26's would work for you best overall. Might take a little bit to plane out at 5000', but will be better cruising and faster top speed than 24's. You will likely be all over the rev limiters at lower elevations with the 24's. Good that you are planning on contacting bblades, he will definitely get you set up correctly and tweak your props if needed. Just make sure the engines are running up to par and nothing else is going on here. Good luck!
4mulafastech 08-17-2014 09:57 AM
Well that is a little harsh... Lol!
About the only thing I would recommend to Formula is to have hydraulic steering and K-Planes standard. Makes the 292 a whole new boat, both safety and performance wise. Other than that the 292 is a great mini-offshore package!
pasquesi 08-17-2014 10:30 AM
Originally Posted by stimleck (Post 4172918)
29 ft boat with twin engines that needs all that work to plane out? that sucks what was the designer thinking? my **** box with a single engine doesnt need that much work and will still do almost 60
You're talking out of your ass. There are cats and V's with 2100HP that have an incredibly hard time getting on plane. So much so that aeration tubes are added to allow the props to blow out to get the revs up.
Made It Rain 08-17-2014 11:16 AM
2012 Formula 382 with Ilmor 725's aerators.http://www.youtube.com/watch?v=nor3LFFjlBA
looseconnection 08-17-2014 04:16 PM
Your rucking fetarded.
SB 08-17-2014 08:57 PM
Your HP loss computed from your HP of 320 at sea level and Elevation of 5000 feet is 48.00 HP loss.
Who doesn't think he doesn't needs smaller props now ? and/or more gear ? or Nitrous ? LOL.
SB 08-17-2014 09:10 PM
Stimleck - why don't you try helping the OP ?
How would you like the next time you have a question that you want help on, some of us just tell you your boat is a hunk of schit so why bother ?
Did you read my post just above your last one ?
That's help.
mptrimshop 08-17-2014 09:12 PM
Wow.....
pasquesi 08-17-2014 09:14 PM
Originally Posted by stimleck (Post 4173211)
hey dip**** are you in the retard club also? those 2100 hp machines are specialized high speed off shore beasts they are not entry level junior offshore boats. Skaters porpoise more than the average boat at low speeds but hey are ****ing beasts at high speed, these are the types of sacrifices that should be expected for the absolute performance. The best anyone is doing on this thread is 70 Ha! you get beat by fully loaded bass fishermen lmao!
Just because 3 or 4 of you suckers are driving he same chitty hull doesnt mean its justified, when you are doing 90 or are more than 38 feet you can then make excuses for chitty performance
Not even worth a response. You are simply mean spirited and obviously interested in yourself. Go away.
SB 08-17-2014 09:16 PM
Hey, looks like Stimleck get's his chance,
He just started a thread asking for advice.
How's this for his own answer back ?
http://www.offshoreonly.com/forums/d...nge-valve.html
hahahahahahahahaha
Made It Rain 08-17-2014 09:17 PM
My boat is over 38 feet, does 94 MPH at 3600' elevation, 98 MPH in the ocean and I have the same "chitty" hull as everyone on this thread. I don't need to make excuses though, it performs great! I pass cats all day long when the water gets rough, the rougher the better!
pasquesi 08-17-2014 09:21 PM
Nice! Bad ass package man with the Ilmors!
Zone 5 08-18-2014 12:27 AM
4" of pitch is going to give you "roughly" 800 RPM. every inch of pitch is worth about 150-200 depending on the boat. So, as someone posted, going down toward sea level you will be bouncing off the rev limiter. I'm not sure what the 6.2's limit is set at, but you will be close to/at it with the 24p. I'd believe what Formula told you.on prop pitch.
and yes, 24p will make the boat plane a lot faster.
This is REALLY important. The 271 and the 292 both came from Formula with the spacer toward the rear of the drive. They did this to stop bow steer.(according to their tech reps and told only after I told them I had switched it. They weren't happy to admit it) My 271 was a pain in the azz to get on plane till I moved it to the front. then it was much better. Still not a drag boat by any means but way better. My 271 with a full load of people still did not like getting on plane without some people moving forward. when the motor was redone, even with 630 HP, it was drive in, tabs down, 3000 until it rolled over and then go from there. The 292 and 271 are very similar in planing ability.
Zone 5 08-18-2014 12:33 AM
Originally Posted by stimleck (Post 4173205)
this is an entry level offshore/family boat, have you ever seen the advertisements,
no one with the slightest clue would ever mistake any Formula for an "entry level" boat.
stimleck 08-18-2014 06:54 AM
Tedorama I apologize if you took offense to my comment it wasnt personal to you. I just think what you described should not be acceptable in a boat that doesnt reach high top speeds.
Best to All,
Ted
RT930turbo 08-18-2014 07:54 AM
Just spit my coffee out on that one!
Tedorama 08-18-2014 08:15 AM
None Taken!. I sell Porsches for a living so I always hear what a piece of CHIT they are from the uninformed! My last 2 were CHITTY boats as well, a Cobalt 255 496HO and a Cobalt 282 640HP twins as I am new to the boating world and trying to find out what my 15 year old son and I like best before he's off to College and gone for good. I tend to agree with all the advice here that mirrors what the Formula Propulsion Engineers that 24Ps will work best for higher altitudes.
looseconnection 08-18-2014 08:17 AM
Originally Posted by stimleck (Post 4173208)
its you that is the ****ing retard, there are single engine bow riders doing almost 60 that plane in 5 seconds without moving people around, they have fridges and coolers and sinks and mini stoves, only a ****ing retard would think that going through so much work to plane out yet your top speed is 70 is normal.
\You are not driving a 150 mile an hour cat you have a baby offshore that would get spanked all day by a bass boat. (i would be ****ing embarrassed to ask the chicks to go to the front)
Obviously the set up is wrong with the OP's boat. Your disability to comprehend this verifies your rucking fetardedness. While by 292 does not hop up on plane like a single engine bow rider, it does so without having to get people to move to the cabin and or sawing the wheel. All stepped hulls have quirks and slower than average planning is a quirk of the fastech, but I have yet to hear of a fastech hooking and spinning. The list can go on and on.
As far as the bass boat goes....again you are missing the entire concept of a bass boat vs "baby" offshore boat. If you cannot tell the difference between the two, not one *ucking soul can help you on this site.
pasquesi 08-18-2014 09:37 AM
Originally Posted by stimleck (Post 4173390)
Loose connection, keep your personal insults to yourself and stop being a keyboard cowboy You are simply making excuses for this hull because you own one.
The other owners experiences support that this hull doesn't plane well which is unacceptable
If you have any other comments to make directly to me send me a pm and ill give you my phone number, no need to continue distracting from this thread.
Unacceptable? To who? You? You appear to have virtually no offshore boating experience evidenced by your comments here, and the idiotic thread you started about oil drain hoses.
If you are so emotionally invested in being a vocal spokesperson for the hard to plane Formula, give Scott Porter a call. I'm sure he'd welcome your comments.
looseconnection 08-18-2014 09:48 AM
What is really cool is if you select to ignore some one their responses are deleted on your screen. Now I do not have to read all of stimlecks BS.
Sydwayz 08-18-2014 09:59 AM
FINALLY!
Someone has made the crossover from YouTube comments expert, to Facebook comments expert; all the way to OffshoreOnly thread reply expert.
I certainly am glad this has happened. This website has been garbage for 12+ years. Hopefully everyone can follow this new trend of derogatory posting to turn this place around.
:riding: :rolleyes: :Whatever:
(Be careful not to fall off your imaginary horse)
stimleck 08-18-2014 11:01 AM
Brian I'm not sure what is up your butt but I disagree, this website is awesome except when a a couple of guys act like teenage girls because they don't agree with someones opinion.
Post away I'm not going to feed this crap anymore, people have better things to read
Originally Posted by Sydwayz (Post 4173426)
FINALLY!
Tedorama 08-18-2014 11:51 AM
This is REALLY important. The 271 and the 292 both came from Formula with the spacer toward the rear of the drive. They did this to stop bow steer.(according to their tech reps and told only after I told them I had switched it. They weren't happy to admit it) My 271 was a pain in the azz to get on plane till I moved it to the front. then it was much better. Still not a drag boat by any means but way better. My 271 with a full load of people still did not like getting on plane without some people moving forward. when the motor was redone, even with 630 HP, it was drive in, tabs down, 3000 until it rolled over and then go from there. The 292 and 271 are very similar in planing ability.[/QUOTE]
What's the procedure to move the spacer to the front to allow more trim in. I fairly mechanically inclined, so a photo, detailed explanation, or a link on doing this procedure would be very much appreciated
