-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   242ss/ls prop recomendations (https://www.offshoreonly.com/forums/formula/317452-242ss-ls-prop-recomendations.html)
GLENAMY 242SS 08-31-2014 09:39 AM
What prop/s and pitch have you found to be best for 1987 242ss? Any recomendations and experiences welcome 454 mildly warmed up.
Thank you.
Mohawk242 08-31-2014 04:52 PM
I run a 23P Mirage Plus on my 242 LS with a 450 HP 454.
86242ls 08-31-2014 05:28 PM
+1 on a 23 mirage plus
GLENAMY 242SS 08-31-2014 07:33 PM
What rpm and speeds are you seeing?
BY THE WAY I HAVE 1.32 GEARS
Mohawk242 08-31-2014 07:43 PM
5200 and I consistently see 66-67.
masi242 09-01-2014 07:54 PM
I run a bravo 1 four blade 22 p labbed a little.
GLENAMY 242SS 09-01-2014 08:17 PM
Masi242 what rpm/speeds do you see?
I AM HOPING TO DO PROP TESTS NEXT WEEK, LOOKING FOR WHERE TO START
THANKS ALL
moparjet 09-02-2014 06:27 AM
is your drive a alpha or bravo? i run a bravo 1 with 23p mirage plus. 65.5mpg best i have seen
masi242 09-02-2014 07:48 AM
I have the alpha drive 1.50 ratio with the 454 and max rpm trimmed up is about 4500' I believe max on my engine is 4600.
GLENAMY 242SS 09-02-2014 08:27 AM
I also have the alpha drive 1.32 gears
