-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Help!!! 242ls wiring problem (https://www.offshoreonly.com/forums/formula/321016-help-242ls-wiring-problem.html)
Jonesyfxr 12-11-2014 06:51 PM
I found this, maybe it'll help you......
http://www.marineengine.com/parts/me...ERCACCB/26.gif
FIXX 12-11-2014 07:09 PM
Originally Posted by lil red (Post 4233535)
They all have the orange wire. That's power feed to the ignition switch??
the orange thick wire goes to the ignition,,it then goes to the older alternator to turn it on..fiddle with the plug,,it will plug together,,just make sure the big pins are aligned..
smokin' gun 12-11-2014 07:56 PM
these guys are correct it will plug in ive done it many times
502formula 12-12-2014 06:38 AM
All the pins do line up, it's just the boat harness has the 3 big pins and the engine has 2 big pin holes. That one pin is what's messing me up
Unlimited jd 12-12-2014 06:58 AM
Email me a picture. The only difference I've ever seen is in the small pins. And I've swapped motors around in close to 100 boats.
[email protected]
smokin' gun 12-12-2014 06:59 AM
then maybe 1 pin broke off from a prev harness when pulled apart ,and its still in the engine side ...I will tell you they will plug into each other .I had an 88 formula 24 ss I did a while back ,,I put a 496 ho in ..never changed harness .plugged right in no adapters nothing
502formula 12-12-2014 07:27 AM
Just e mailed you
502formula 12-15-2014 08:09 AM
Bump
