Hard to start problem.
I have a 1999 382 Fastech with 502 mags. Seems lately each time we go out the engines at one time or another don't want to start.
I'm beginning to think its heat related ?? It's been in the mid 90's and sunny here. This past weekend we had ran out in the gulf for a bit and then to an island to swim and listen to the radio. I'm always paranoid of the batteries going dead so I start the engines after about a 1/2 hour of sitting. What happens is the engines crank as normal, seem to start to fire and then die. I try again and again. Usually it seem when crack the throttles and randomly it lights and once it revs and starts is good. The second engine still wouldn't start so I let it set with the first engine running for about 5 minutes and the finally right side started. What would be common to both engines ?? The right side seems to do it more the left. Never does it on the hose. Only seems to be doing when heat soaked. Thanks for any insight guys. SJ |
If their mag MPI, cool fuel engines, its defiantly heat related, when you say right engine what one are you referring to, do you open the hatch a bit when stopped,
Yes, I would concur that it is heat related.
502 MAG MPI's are susceptible to heat soak / vapor lock - the first gen with the VST, in particular. Especially of your a using ethanol fuel from the local gas pump. Mercruiser put out a technical service bulletin on the issue. |
heat soak.....lift the hatch for a few minutes when you first shut it down to let alot of heat out. open it again 5 min before starting if possible and I bet it never happens again.
Vapor lock.
Many of us have/had same problem on 502 MPI's. I went the Merc route and installed their add-on pump. It worked really well, and I never had the issue again (you can install this yourself easily). Others have run return lines back to tank, installed better pumps, etc. Many ways to skin a cat. |
Originally Posted by 33outlawsst
(Post 4320741)
Originally Posted by Br1dgemann
(Post 4320753)
502 MAG MPI's are susceptible to heat soak / vapor lock - the first gen with the VST, in particular. Especially of your a using ethanol fuel from the local gas pump. Mercruiser put out a technical service bulletin on the issue. What is VST ?? Not sure what your talking about there. SJ |
Originally Posted by easyrider1340
(Post 4320970)
Vapor lock.
Many of us have/had same problem on 502 MPI's. I went the Merc route and installed their add-on pump. It worked really well, and I never had the issue again (you can install this yourself easily). Others have run return lines back to tank, installed better pumps, etc. Many ways to skin a cat. What are the add on pumps you mention ?? Is the main issue just a heat vapor lock type issue or do the fuel pumps get week over time ?? I'm the type if the two fuel pumps were just showing their age I would replace if I knew it would solve the issues. Thanks to you all for your input. It's very much appreciated. SJ |
Originally Posted by SteveFastech382
(Post 4321129)
Yes, I normally run just station pump fuel that usually has the up to 10% ethanol in it. I normally just put low grade in it as well. Would higher octane be less likely to give trouble ??
(Post 4321131)
Drew's Skankizam means put some ethal in it man, LMAO............:lolhit:
(Post 4321147)
battling the same issue, however its only on the port motor, we have had ethonel for a few years, so something has changed, everytime I ask someone i get nothing except changing my entire fuel system, there has got to be a reason why now this is happening had the boat 4 years and run it in plenty hotter/humid weather, w/o issue, Ive been running my blowers all the time never done this before, don't think it helps much thou, maybe a little
Originally Posted by 88242LS
(Post 4321162)
Drew I don't know how old you are but back in the day Ethal ( red neck talk ) meant premium, Phillips 66 red in color and about 98 octane, that's all
(Post 4321217)
Thanks guys for your input. I'll let you know what I figure out. SJ
No it's an additional pump that helps to push the vapor "bubble" through the upper fuel system and through the injectors.
One was just posted for sale. I think I paid about $400 for my kit - this one is cheaper. http://www.offshoreonly.com/forums/s...3-new-box.html
(Post 4321131)
did u ever get anywhere on this? had it home last week and I found the return line from the bottom of manifold plugged solid, I think the line has deteriorated due to ethanol, I unclogged it, ran all new lines, put a can of k100, and filled up on non E and did not have a issue last weekend, I will know more after this weekend it is sposed to be hot, but so far I thinking maybe that clogged line, but what throws me off is the fact that both motors were plugged, only having a issue with the port, we shall see,
I still have one engine out and it will be going back in Monday. I'm putting two new fuel pumps on and the new cool kits too. Not to mention all new exhaust manifolds, risers, and elbows. Lol. Should be back out next weekend.
(Post 4321129)
What is VST ?? Not sure what your talking about there. SJ Try to stay away from regular pump gas with ethanol. In Florida, non-ethanol fuel is called REC-90 and many road stations are selling it. Try to use that instead. Ethanol is an alcohol which has a lower boiling point.... when the engine compartment gets warm, the alcohol boils, creating pockets in the fuel lines and fuel rail. I think this has been kicked enough, but VST is the Vapor Separation Tank, it is mounted on top of the engine and at the rear port side. Fuel gets pumped into that little tank via a mechanical pump mounted on the raw water pump (or maybe a regular mechanical fuel pump, depending on engine vintage - not 100% certain on that), and then a high-pressure pump in the VST tank pressurizes the fuel rail. |
Great info as well. Thanks guys.
| All times are GMT -5. The time now is 04:54 PM. |
