I have an 05 with 500efis and XR drives. Hit 79 this summer with 30p 4 blades. Boat came with 26p 5 blades and I was told it would hit 81 but that seems optimistic. Best I saw with the 5 blades was 75.
Mine will do 80 - 81 w 500 efi's and 4 blade 30 P props, XR drives, moderately loaded, in the ocean.
Bill, what year is your boat? Did it come with 5 blades and you switched to 4?
Originally Posted by D2HP
(Post 4374951)
I took a quick last run of the season and clicked off 80@5100rpm. This was with less than 1/2 tank of fuel in 1' chop. Again here is my specs. 500EFI's, std 1.5 Bravos, std 30" Bravo 4 blades.
I'm thinking 2 mph with less fuel and more time to trim it out. Not to mention the original plug wires from 1Q/99... |
Noticed my HPs have the original Mercruiser wires from 1995. I would like to change them out to the long style plug wires, with the GIL exhaust it is a pain to reach the 90 degree style wires. Sounds like she is pretty strong hitting 80
Yes I'm happy with it.
Maybe a set from Jegs or Summit racing will suit you. |
These are some pretty strong numbers I'm reading. I've always been a fan of the 353s but never paid much attention to their performance numbers. Per BoatTest 525s in them is an 80mph boat, so 500s hitting 79-80 puts a smile on my face as I'm seeing more and more 353s on the market with 500s. I'm even reading that the 496s are a 73-75 MPH boat.
Boat Test was off with the 525 #s a properly set-up 353 will run 83-85 MPH real numbers.
1 Attachment(s)
[ATTACH=CONFIG]548697[/ATTACH]
Testing a pic upload |
| All times are GMT -5. The time now is 12:43 PM. |
