-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   292 fast tec stepped hull (https://www.offshoreonly.com/forums/formula/332281-292-fast-tec-stepped-hull.html)
myattitude 11-08-2015 11:35 AM
Hello guys, I have a couple questions, my buddy is looking into a 292 fact tec stepped hull. I have no idea about handling and turning with the stepped hull. He has caught the bug and wants a formula 292. Twin small blocks. 2002 or newer. How does it turn? Speeds? Better years? How does it compare to other boats similar size? Thank you.
COOPS 11-08-2015 02:04 PM
I have a 2004 292.
Very stable boats and I feel confident driving it like a jetski if you want to. They need external hydraulic steering. The 26zx Donzi I had before would hook and catch all the time when turning. I never get that with the 292. You still need to be mindful that you are in a stepped hull when getting agressive in turns.
diverkr 11-09-2015 05:25 AM
Never had any issues with stability. I have Prochargers on my 2002 and have seen speeds over 80 mph. I do have external hydraulic steering which seems to be less common on newer 292 models.
4mulafastech 11-09-2015 12:47 PM
I have a 2006 292. What the others have said, no problems with turning or handling. Highly recommend hydraulic steering. I had K-Planes installed replacing the stock Bennett tabs which improves rough water running. Mine has 320 HP 6.2 liter small blocks and runs 68-70 mph anytime and 70-72 mph in perfect conditions like light load, good wave chop, and cool weather.
myattitude 11-16-2015 12:21 PM
anything else? 377 blue motors vs 6.2? why no k planes?
racinfast002 11-16-2015 04:11 PM
I'd put in him a super quick 312 if he wants to go a little bigger.
hullofjustis 11-16-2015 04:38 PM
Stepped hulls you are supposed to keep the trim positive when turning. At least that is what i was taught at a scarab racing school i attended back in the day. They say that using negative trim cause the transom to lift which then traps air under hull and can cause them to spin out or flip
88242LS 11-16-2015 08:04 PM
292-377= sweet! gotta look for them thou
Splitdecision271 11-17-2015 11:12 AM
Great entry level twin engine performance boat. Handles chop very well, not the fastest out there but very solid and dependable. I don't get too aggressive with her, but I can lay her over no problem and feel 100% confident doing so. Enough cabin room for 2 if you overnight occasionally. I spent several nights on my 292 this past summer, it's tight quarters but I can get a reasonable nights sleep with just a fan to circulate air in the cabin.
The blue 377 scorpion motors are an awesome package but your only going to find them in older models as Formula stopped offering that engine package a while ago. Not sure if it was because there were issues with the motors or they realized it was too much motor for the boat without k-planes and hydra steering which they didn't offer both options on the 292. So you'll either have to add them yourself or find someone who already did.
Keith Atlanta 11-17-2015 11:34 AM
But what is a 292 like with K planes? I always thought a 292 with some 377's or better yet, two LS motors would be a blast to drive.
