-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   353 - New in-Dash GPS thoughts? (https://www.offshoreonly.com/forums/formula/341276-353-new-dash-gps-thoughts.html)
JTeam 01-28-2017 11:29 AM
1 Attachment(s)
I had the same setup as D2HP and here is what I did. I removed the bezel rings and relocated 2 gauges. I wanted to maximize the screen size.
[ATTACH=CONFIG]564192[/ATTACH]
snowrunner 01-28-2017 12:35 PM
I went with the Simrad Go5 since I could also toss the old stereo and remote, all controlled thru the GPS via NMEA 2000 network. My goal was to relocate fuel and volts.
Anyone have thoughts on the old trim rockers or go with the carlings like I see in many new boats?
D2HP 02-05-2017 08:01 AM
JTeam, you were able to keep you old dash and made that work? What is the footprint on the Raymarine?
JTeam 02-05-2017 12:49 PM
Yup. I had to remove the rings around the gauges to make room, but I like the look better anyway. It is a tight squeeze but at least I kept the old dash. The unit is an e7, here is a link that will provide the dimensions. http://www.raymarine.com/view/?id=29...id=96&col=3021
D2HP 02-05-2017 01:30 PM
How hard is it to remove the rings? I like the look without better, and it gains some space.
JTeam 02-07-2017 07:06 AM
Just remove the gauge and they will fall off. The rings are a decorative add-on.
snowrunner 02-21-2017 06:11 PM
Anyone know how to get the Mercury Racing Trim Bezel in Chrome?
RGPIII 07-06-2017 07:33 AM
Originally Posted by Rippem (Post 4523566)
watch for the latch-catch and the hinge-plates
when it starts getting tight they are a bigger issue than you'd think
Can you elaborate on this a little? is it more than just a latch sticking? or out of adjustment?
Rippem 07-06-2017 07:38 PM
no,
it's about cutting the gauge panel for a plotter R or L (not center) and realizing the hinge plates for the panel won't let you use quite all of the width.
and on the top (if cutting for full or high center install) consider the "catch" for the panel "latch" release can also encroach on install space at the top.
