353 Raw water pump replacement - boat in water?
Got stuck in a shallow grassy - mucky area, likely destroyed both raw water pumps (over-heating). I have the water pickups on the nose cone, i think they are prone to plugging?
Anyway, was just outside our marine when this happened (depth finder didn't work) and was able to get back to the slip. Never done a swap while in the water, any tricks or things to avoid? Thx |
Being in the water won't change anything. I had my pick ups in the nose cone on my old 353 and I had the same issues since i boat in shallow water, I drilled the out drive for dual water pick ups and never had an issue after that.
If you don't have water shut offs (mine does not) then you have to pull the boat. If you have water shut offs between the transom and the water pump then just close them and you are all set.
You can likely change in the water. Just hold the stiff hose up high (above water line), so water doesn't rush in.
However, if you have trashed the impellers, then you'll need to flush out the cooler(s) - otherwise, you'll have low water pressure and possibly an overheating condition. Generally, most people just flush with water, which is not always effective. You'll need to get the impeller pieces out of the cooler(s) with a pick or wire by poking through the holes (in the cooler). Good luck! |
I always try to "rebuild" the impellers from all the pieces to make sure all are accounting for. If any are missing then you need to back flush from the t-stat. Also, little trick I learned. McCormick seasoning bottle fits perfectly into the end to act as a plug for the inlet hose.
Originally Posted by Splitdecision271
(Post 4490031)
My 353 has the flush kit, was able to run both motors when everything was installed again (had the hose running on the one). Concerned that I am plugged at the drive and likely will motor back to the launch on the port motor only. I'd love to know what the mod is on the second pickup location. If I recall, didn't Merc go away from the pickup in the nose cone after only a few years? My 2000 Bravo 3 had the traditional side pickups, but not sure if they are the same as the Bravo 1's in 2000? |
The impeller will last about 5 min. without water. maybe blow air out through the hose to clear your pick up.?
If you're concerned with the drive being plugged, then back flush it from the seapump hose.
If you shredded the teeth off the impeller you need to back flush the system. Particles can not make it past the oil cooler. Remove all the hoses from there and run a hose through them. Using the flush kit will not get the particles out because the impeller pieces are on the other side of it. Jeff Wurl
Drives are back in working condition :)
Used the flush system to back-flush the drive, cleaned out the mud from the system. Ran it for a hal hour out on the lake, both ran at 170F. Back at the well I think i found the source of a different problem, oil buildup on the from of the Port motor. Had cleaned everything, after a few WOT passes - temps checked out ok. But, found oil leaking from the dipstick handle. Not something I'd expect at 340 hrs, 75 hrs after top end redone ( but reading that this is somewhat common on a 502?). looks like its been there for a long time, assuming blowby? :(:(:( Anyone have this issue? Doesn't happen anytime but at WOT. |
Probably is Blowby...any leaking up top around the valve covers?
No, coming only fro the dipstick.
Make sure your crankcase isn't over full. It's easy to do...that can cause oil to climb out of the pan at high RPM with a high volume/high psi pump.
Looks ok against the stick.
Will be changing the oil this weekend for winterization. Will be running 15-40 Mobil 1, not sure what the previous owner used (guessing Quicksilver from the bottle left in the boat). Trying to figure out what people are doing to deal with the issue, as I see blow-by is a common issue on 502's. Mine are MPI's, with a PCV valve (new). Thx, Eric |
| All times are GMT -5. The time now is 05:18 PM. |
