353 FasTech Handling Question >
Old 03-22-2017, 09:44 PM
Registered User
Default 353 FasTech Handling Question
I have a 2008 353 FasTech and the K-Planes are mounted horizontal (parallel to the water) rather than in line with the V of the bottom.
When running even at moderate speed if the boat starts to lean off to one side and I correct with tab after a while it will take off and lean to the other direction.
It does not seem want to be stable. My previous two boats had the tabs mounted lined up with the V on the hull and did not respond like this.
What am I doing wrong?
Thanks in advance.
Dave
Dkahnjob is offline
Old 03-23-2017, 08:58 AM
Mentalpause's Avatar
Another way to correct lean is to slightly trim one of your engines up or down to counter the lean, many times caused by wind direction. The benefit of this approach is you keep your K-planes at the same location on both sides of the boat which keeps the boat more stable if you hit a rogue wave.
Mentalpause is offline
Old 03-23-2017, 10:38 AM
Forum Regulator
Sydwayz's Avatar
Received 1,212 Likes on 525 Posts
Very true. Once I had this explained to me, I practiced it and rarely ever use(d) tabs in differential positions except in really strong crosswinds.
Sydwayz is offline
Old 03-23-2017, 11:01 AM
Yeah, me too. Especially at LOTO on a snotty day where you never know when you might hit a rogue wave with one tab offset from the other and have an unpredictable outcome.
Old 03-23-2017, 12:21 PM
VoodooRob's Avatar
Had an 05 353 with 525s and ITS, tabs were mounted at an angle from the factory. On really gusty days the boat did have a lean that was odd. It was hard sometimes to get out of it once in. That boat was very dialed in and ran very good numbers so I just attributed it to the design and drove thru it.
[ATTACH=CONFIG]565815[/ATTACH][ATTACH=CONFIG]565816[/ATTACH]
Attached Thumbnails 353 FasTech Handling Question-20150803_185204.jpg   353 FasTech Handling Question-boat-3-resize.jpg
VoodooRob is offline
Old 03-23-2017, 04:27 PM
Registered User
Thanks guys, I appreciate the input and will try it next time out.
Dkahnjob is offline
Old 03-23-2017, 08:23 PM
Naw, It has more to do with the drives hitting the tabs mounted parallel with the hull. Mounted level the interference is eliminated
fossil fuel is offline
Old 03-25-2017, 08:40 AM
Where To
axapowell's Avatar
So, I personally would never try to correct wind by counter trimming an outdrive. If you are dropping a trim tab and the boat is rolling over too far, you are over trimming. It take a couple of seconds for the boat to react to your input.
Try making slight adjustments to the tabs, a little goes a long way, you don't need much to get a reaction. Putting
undo pressure on your steering and tie bar by counter trimming could have negative results.
Dave
axapowell is offline
Old 03-25-2017, 09:03 AM
Registered User
Dave
Thanks Dave. I guess maybe I am not waiting long enough for a reaction.
Dave K.
Dkahnjob is offline
Old 03-25-2017, 11:26 AM
Dave
Professionals in the boat industry taught me that little trick. As you indicated with the tabs you are just making minor tweak adjustments that don't put undue stress on anything.
In many cases your trim button doesn't raise both drives perfectly synchronized anyway.
