-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Height of a 382 (https://www.offshoreonly.com/forums/formula/34721-height-382-a.html)
flimflam 10-12-2002 11:59 AM
Height of a 382
Building the dream garage for my next boat. Will 12' of clearance make it? Anyone know the actual height on trailer ?
mopower 10-13-2002 09:52 AM
FF,
What model are you taking about? If its a PC it could be close :eek: . Fasttech SR1 series should be no problem. My 272 won't clear my 8' but I'm talking like and inch.:mad: . Don't forget , different trailers can make a difference in height. Roller trailers are usually higher as compared to bunk trailers:cool: .
flimflam 10-14-2002 11:01 AM
382 Fast Tec 1999 to 2003
mopower 10-14-2002 11:07 AM
FF,
You should get through a 12' high door with the engine hatch open:D :D.
Now don't forget to make it wiiiiiiiiiiiiiiiiiiiiiiiiiiide enough:rolleyes: Forget 8'. it's a sqeeze at 9' ,no room to manuver. 10' is a pretty safe minimum.:D
flimflam 10-14-2002 04:20 PM
I checked with Formula and it looks like 8'9" is the current height on a trailer. I set the width to be around 24' wall to wall. I am stoked, just the thought of being out of the elements, AZ is pretty harsh on colors. Thanks for the help, now I need to find a 382!
mopower 10-14-2002 05:15 PM
FF ,
I'm talking about the DOOR width. Yeah the suns bad enough on things in Jersey. I had a brand new car trailer and the tires were all cracked after only two years. Took them back to Goodyear and got four new radials for just over $100. Now I keep them covered with tire covers from a camping supply.
