Wanted - SR1 Helm/Dash Pieces
I'm looking for the platic plate that goes along the bottom of the gauge panel. Mine was replaced with a piece of plate aluminum, and I'd like to put it back to stock so it matches the first mate's glove box. I also miss having a cup holder at the helm!
I believe the pieces are all the same from '86 to '91 on the 311, and '87-'91 for the 242-292 should also work. Cup holder size isn't a concern because I'm going to cut the piece for a large cup holder. I would also like the the pieces from the first mate's station to keep everything matching, but this isn't necessary. Lastly, the lower plastic pieces for the ignition and switch gear (on either side of the wheel) are needed for another project. Thanka! |
I have the lower right plastic toggle switch panel if that's one you need.
What do you want for it?
| All times are GMT -5. The time now is 02:28 PM. |
