-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Livorsi vs Autometer or Gaffrig Gagues (https://www.offshoreonly.com/forums/formula/350273-livorsi-vs-autometer-gaffrig-gagues.html)
snowrunner 10-11-2017 01:18 PM
Looking to replace my original failing Gaffrigs (Tach hangs up). I actually like the quality of the Gaffrigs, but the bezels need some updates. Anyone know which hold up better? Livorsi or ProComp Marine?
I know if I go Livorsi that I'll need to do a lot of in-dash wiring changes.
Griff 10-12-2017 01:39 AM
If your guages say Gaffrig Precision Instruments, they are actually Livorsi.
There was a lawsuit between Gaffrig Precision Instruments(Livorsi) and Gaffrig Performance and Livorsi lost the name.
snowrunner 10-12-2017 05:55 AM
Didnt know that. These are the originals from 1998.
Wally 10-12-2017 09:33 AM
and if you look on the outside edge of the face under the trim ring it will say its made by autometer in tiny letters :D at least the gauges i had back then did
snowrunner 10-12-2017 04:00 PM
I see that Livorsi's are made by Autometer - reading around the rim, will check my old Gaffrigs
snowrunner 10-12-2017 04:20 PM
Originally Posted by LS1 (Post 4587654)
Snowrunner PM Replied.. Phragle, shoot me a PM.
:D
LS1 you mailbox is full, can't respond
formula1 10-15-2017 07:53 PM
Will the Gaffrig or Livorsi gauges be an easy swap in a 311SR1? If not, other than stock VDO, is there other options without having to rewire the whole boat?
snowrunner 10-15-2017 08:37 PM
I had VDO in my 2000 280SS, was able to switch them to Faria (due to size of the VDO hole) without any wiring changes at all. I would assume new Faria and Autometer are the same wiring.
Would almost consider Faria for my replacements if they had the right color combos.
formula1 10-15-2017 08:57 PM
Anyone know off hand what size the 311, tachs, speedo and smaller gauges holes are?
boatnt 10-15-2017 09:19 PM
SS Competition 6 Gauge Set, Stainless Bezels, USA SELLER | eBay
for the money you can not beat this gauges,,,have tried the big 3,,spent a lot of money just to be disappointed,,
also think the guy that sells them is a member here
waveryd 10-15-2017 11:55 PM
Replaced Gaffrigs in a '98 382 with Autometer ProComp Marine and GPS speedo. Very happy with quality and performance. Solved lots of problems with erratic readings, bouncing needles, etc.
LS1 10-16-2017 02:32 PM
Usually 3-3/8" on tach and speedo and all other gauges 2-1/16"
Wally 10-16-2017 03:12 PM
Yep goes by SSComp
masi242 10-16-2017 08:57 PM
I wasn't sure these guages were still around i bought some for my Dads boat years ago and still working fine, might be a nice upgrade for the spring. Is it that simple just wire them up.
TomZ 10-17-2017 08:18 AM
I like the SS gauges for non-performance applications only because there seems to be limited availability. Oil temperature and water pressure would be needed to make these more attractive for a performance boater. I have not seen these available on the eBay store.
