-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   400 ss engine hatch actuator (https://www.offshoreonly.com/forums/formula/352004-400-ss-engine-hatch-actuator.html)
Wilks 01-27-2018 09:49 AM
Can you point me toward an engine hatch actuator for a 400 ss beyond going back to formula? What is the voltage, length and load rating needed?
Advantage 03-23-2018 05:47 PM
Did you ever get the answer to your question? My hatch actuator needs replacing. Thanks.
Wilks 03-23-2018 09:37 PM
yours is the same as mine was. I bought a heavier duty one off amazon for $350. 1000lb capacity. Was a little different so the extension did not fit but I think I can make the extension work.
Warner Linear K2G20-12v-BR-18 B-Track K2 18" Stroke Length Rugged Duty Actuator
Advantage 03-24-2018 11:05 AM
Thanks for your help Wilks! BTW, in the other thread, the couple from Rochester isn't the Moe's is it?
Wilks 03-24-2018 09:10 PM
Yep
Advantage 03-26-2018 09:29 AM
Originally Posted by Wilks (Post 4617809)
Yep
Good people.
Advantage 05-09-2018 09:54 AM
Wilks, did you get that hatch actuator to fit and work? What modification if any did you need to make to accomplish this?
Wilks 05-09-2018 08:54 PM
It’s in and working less the upper extension piece. Still need to figure out how to make it work
Advantage 05-10-2018 07:31 AM
Okay, thanks for getting back to me. Was quoted $820 for the actuator from Formula. I may just buy the damn part.
