252SS E-T-A circuit breaker size?
1994 252ssI've got an engine/ignition cutout issue that I'm trying to diagnose. I'd like to eliminate the E-T-A ignition breaker as a culprit by swapping it with another in the block, probably the wiper breaker. Are they all the same size on my boat, i.e. Interchangeable? |
The answer, as I suspected, is no. Same "size", but different Amps. According to Formula Tag the ignition and macerator breakers are both 20 amps. They also sent me a great wiring diagram. |
| All times are GMT -5. The time now is 11:19 PM. |
