02 292 vs. 91 311
Well, the 311 in question has been ruled out. Too many unknowns for me and Id like to have a turn key reliable boat.
Now considering a 03 312 w/ T-496magho. Asking 50k..boat doesnt seem to fit the trailer but could work for now as Id probabky upgrade in a few years to a loadmaster as theyre reasonably priced and local to me. Boat other wise looks pristine.
What is everyones thoughts on a 312? Doing research on here yields mixed results. Some said the ride left much to be desired. Logic says 2 running surface and 1000lbs would lead me to believe it should be better than the 292?
Both boats are in Maine, which means itll be awhile before I have the chance to ride in each.
On another note, what is the safest way to handle the money in a private sale for both parties?
If you're up to $50K, your also in the ball park of a 353 - much better ride than both.
I started with a search for a 292 or 312, ended up with a 353. Never thought I could get a 353 in the price range of a 312, but was able to find one. If you can go bigger, I would highly suggest it.
If new technology is not that important to you, and you want a big water boat with comfy overnighting in the cabin, I'd suggest you continue to look for 311's or even a 357 (that's a big boat) with stock engines. You can upgrade the engines if you want, but buying an older boat with stock engines suggests it was run by a guy who didn't want to be the fastest, and likely drove it easy. In the newer boats, I'd try to swing a 353. The 312 really is not that big, and get smaller when overnighting on it.
Remember what was said above, some Formulas don't include the swim platform in the length, and some do. If the platform was bolted on, it isn't included (even if the platform looks like it was molded in). If the platform was in the hull mold like the latest ones, than it's included in the measurements. So the 353 is only 2 feet longer than the 311, but the 311 feels like a bigger boat.
