-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Original cockpit switches 87 242ls (https://www.offshoreonly.com/forums/formula/363806-original-cockpit-switches-87-242ls.html)
Tony S 11-09-2019 05:23 AM
Does anyone know where I can purchase original Formula cockpit switches? I'm planning on replacing two aftermarket switches with originals.
Thanks in advance
Tony S.
GLENAMY 242SS 11-09-2019 06:41 AM
You are going to need to find somebody upgrading their dash.
These breaker switches are no longer made and are absolutely impossible to find and when you do find them they are usually very brittle and expensive.. Keep a sharp eye out for somebody parting out an older formula.
Good Luck
oconnor marine 11-11-2019 10:07 AM
I had the same issue with my 1988 red toggles. I replaced them allhttps://cimg9.ibsrv.net/gimg/www.off...2a0ce96a46.jpg
ph1971 11-11-2019 01:59 PM
I gave all of mine to a guy that posted on here a year ago. You are 12 months late. Be sure you get the right switches because they are amperage specific on the old red toggles. Switch/breaker.
Redneckcustoms13 11-11-2019 02:06 PM
I almost did the picture above with regular toggles and fuses. But I kept the factory ones. They are still available in solid black but obviously arent lighted.
