-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   smartcraft/vessel view/ fuel level (https://www.offshoreonly.com/forums/formula/368392-smartcraft-vessel-view-fuel-level.html)
30outlaw 09-08-2020 11:31 AM
so I ran smartcraft to the helm, using on older vessel view race edition that I had collecting dust on the shelf and have a pair of the MX 6.2's. reassigned the ecu's everything seems to work. Went the next step, called Mercury tech support got the part number for the fuel level sending unit harness. engine side is "simple plug and play" (with the exception that neither if the 2 wires on the harness matched the wires on the engine) pulled the terminals out of the wire harness i got lined them up with the engine harness. I called formula got the wire diagram of the boat pink wire on sending unit goes to signal on the analog gauge(pulled the dash down to verify this and it was correct) spliced the pink wire in and nothing..... went through the setup on vessel view several times cant get fuel level to show up. called mercury tech support and walked through everything with them and no joy. they said to take it to the dealer.... Fun fact i also hooked it up the the port engine and did all the setups and calibrations and same thing no joy.... what am i missing?
