Sun Sport and ohers probably question (alarm)
High water alarm, when triggered, does it also turn on bilge water pump? or its only an alarm...
Mine doesn't have an alarm, try filling bilge from hose until alarm sounds, is the bilge pump going?
generally the bilge pumps are wired hot and the when the water level rises it triggers the micro switch to turn on the pump
Originally Posted by GLENAMY 242SS
(Post 4797772)
Yes this is the correct setup. you don't want the alarm going off every time the bilge pump runs...
If you have an auto pump, make sure there is no oil in the bilge. Those coasties will have your nuts for discharging oil in S. Florida.
