Mach Stern Drive Props
THANKYOU DAN!!!!!!!! sent in a set of the mach stern drive props they work we'll but the blades are weld on and the hub barrels are sand cast .They had a lot of holes and was ready to loose a blade we dug the pits and cracks out with a ball burr and welded and finished, balanced to perfection and we are going to mirror polish the props as they had a lot of rust/they will be there friday and thank's again
PROP'S SENT OUT TODAY THEY WERE ROUGH!!!!!!! WE DID ARE BEST ON THESE YOUR TRACKING NUMBERS ARE 1Z770X270317549804 AND # 2 IS 1Z770X270317549868/ THANKYOU VERY MUCH, THE tensile strength is not good it appears there was to much heat when the blades were welded on ???????
Thanks Darin for keeping your word. I hope they look as good as you said they would. I also hope you sent them to me not someone named Greg, my name is Dan.
UH-OH:eek:
OOP'S
DAN ,DAN THE MAN YES, I SCREWED UP SORRY ABOUT THAT .BETWEEN SCREEN NAME AND REAL NAMES , I JUST GOT CAUGHT SORRY.
Darin-do you have/do inboard props too?? Looking for some
18 X 20 X 1 1/4 or 18 X 18 X 1 1/14 four blades. Thanks |
inboard props
INSPTECH,I dont't have any in stock this size, I can repair inboard props up to 36" dia and we will be glad to locate some for you if you need me to,what's uo with your's do they just need repaired or do you want new only? let me know if I can help/thanks
The new boat I got haad bad electrolysis on the props and they are not repairable so I'm looking around to see what's available. Just figured you might have some there, if you hear of any, let me know.
Thanks |
electrolysis/
a decomposing of a electrolyte by a electric current/who glad i have a dictionary, but I knew what you where talking about. if you buy a used set tap the props with a ball ping Hammer (not hard) make sre they have a HIGH PITCHED RING AND THIS WILL TELL YOU IF THEY ARE GOOD, IF THE RIND SOUNDS DULL OR DEAD THE PROPS ARE NO GOOD ( YOU PROBABLY KNEW THIS ) BUT IT'S MY TIP OF THE DAY. I'LL LET YOU KNOW IF I CAN FIND A SET , JUST BE CAREFUL WHAT YOU BUY ON THESE.
| All times are GMT -5. The time now is 08:49 AM. |
