-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   Engine Hatch Switch (https://www.offshoreonly.com/forums/formula/379859-engine-hatch-switch.html)
TBarr10 07-10-2023 07:11 PM
Engine Hatch Switch
Anybody have a part number for the engine hatch switch on a Fastech? Its a momentary on/of/ momentary on DPDT switch, however I believe it has 8 pins instead of the standard 6 I have been seeing.
Wally 07-11-2023 08:04 AM
You can use a standard 6 pin switch if you can live with the switch not being lit up...the extra two pins are for the night light connection...
I dont know who the mfg or part number is but Carling Tech are the most common switches used out there... https://www.carlingtech.com/rocker-s...-series-ii-iii
TBarr10 07-11-2023 02:37 PM
Good to know
