Captain's Call Exhaust
Just placed an order for a 370 SS and one of the options was the Captain's Call Exhaust system.
My dealer suggested not to take it, once power improvement for a MERC TWIN 496 MAGNUM HO B3X W/CWC would be slim for this type of boat. Any comments on the subject? any good or bad experiences? Would appreciate any help on the matter. Francisco |
Assuming the standard exhaust is thru-prop, you probably won't get too much performance gain from the Captain's Call. But I think the sound of the thru hull exhaust would be worth it. One thing to consider is that you'd pretty much have to always run it thru-hull when cruising because you aren't supposed to divert it thru the prop over 3000 rpm(or something like that). I wouldn't see that as a bad thing, but others might.
If it were mine, I'd have the Captain's Call - a sport cruiser should not sound like a Sea Ray...
Hopefully, I'll be able to move up to a 370SS one day, and I wouldn't even think about it without thru hull.
As stated earlier it not a Searay it's a Formula. Either way I' sure you will enjoy it. |
Mathematical justification:
Two 496 Mags + through-hull exhaust (i.e. Captain's Call) = :D :D :D :D There you have it. Now go call the dealer and amend that order. ;) |
The best part about having C.C. is that when you want to hear 'em you can....and when you don't want to hear 'em you don't have to.
I would get it:D |
Any body have any more information on the earlier mentioned comment about not being able to divert the exhaust thru the prop at higher rpm's?
I hadn't heard that before, any thoughts. |
I know I had heard that from a couple places but it took a while to find it. Here's a previous thread - http://www.offshoreonly.com/forums/s...threadid=29817
| All times are GMT -5. The time now is 04:45 PM. |
