-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   water pump runs continusly (https://www.offshoreonly.com/forums/formula/55209-water-pump-runs-continusly.html)
BUSTNOUT 07-23-2003 12:32 PM
THE WATER PUMP FOR THE SINK AND TRANSOM SHOWER SEEMS TO RUN ALL THE TIME ON MY 292, I'M WONDERING IF THIS IS STANDARD OPERATION? THANKS FOR THE INPUT
PhantomChaos 07-23-2003 01:00 PM
Nope.....there is a pressure valve that is near the pump that should let the presure build up and then it shuts off the pump......or you have a water leak.
hot water 07-23-2003 01:27 PM
Definitly not, the water pump should run to build up pressure then shut off. Either the pressure switch is bad, you have a major water leak or the tank is empty
Good Luck
