-   Formula (https://www.offshoreonly.com/forums/formula-36/)
-   -   353 Fastech How fast ?? (https://www.offshoreonly.com/forums/formula/58313-353-fastech-how-fast.html)
THE GOOD STUFF 03-25-2004 05:46 PM
[QUOTE]Originally posted by THE GOOD STUFF
03 353 with stellings boxes & 525 EFI 87.8 gps with merc lab 33 .also ordered from magicfloat [ Speed change. Cut out the deflector plate in the mufflers with a 4 inch holesaw. Went from 87.8 gps at 5200 rpm to 5350 rpm with rev limiter going off could not really see what it really has . I did see 89 gps.I am going to try a set of 30 six blade herings . I hope to get the slip down and maybe gain 2 or 3 mph. Has any one tried the 6 blade hering yet. And could someone figure both of these slip #for me or what is the formula again. Runnig same props both times .My gear ratio is 1.50. QUOTE] Thanks Rex
Magicfloat 03-26-2004 07:43 AM
The Good Stuff is right. 525's don't like mufflers.If you(and the local authorities) don't mind the sound,there is a decent speed increase. I think John B also had a similar gain.
tesheer 03-30-2004 10:19 AM
Rex,
My calculations have you at 20.15% prop slip running 89 mph @5350 revs with 33" props. If you would like I can e-mail you a simple prop slip calculator I wrote in excel.
Double Dealin'
wildthing357 03-30-2004 05:27 PM
Went for a ride on this boat and now the motors are freshen looking to hit 105 mph.
http://www.offshoreonly.com/forums/s...threadid=50963
THE GOOD STUFF 03-30-2004 08:19 PM
tesheer , That would be great.. Thank you for your help. wildthing , That is hauling a$$ in a 35 . Was the boat real stable or was it side to side like it was running out of boat to run on. Rex
wildthing357 03-31-2004 03:53 AM
THE GOOD STUFF,
It was pretty stable, no chime walking. After about 85 the boat was airing out real nice. He is going to try some new 5 blades then maybe some 6 blades and did more head work. This year it should really scream.
baja27 04-02-2004 07:26 AM
My budies 353 runs around 75-77 he does not have extension boxes .Also it's a 98 with carb 500's
Dean Ferry 04-23-2004 07:44 AM
Can anyone confirm the 2000 year X-dimension up 1"
Really curious!
Thanks,
MD
afton 06-28-2004 06:31 PM
Re: 353 Fastech How fast ??
just got a 2002 353 with 500efi no boxes and xz drives from nelems marine in AL about 3 weeks ago finally opened her up this weaken hit 78 with 8 people on board at 4800 rpm so she probably do 83 82 with just me and my son on it .
Donzilla 06-28-2004 08:55 PM
That speed not GPS with 8 on board?
